Results 1 to 5 of 5
    New ROGer Array SimeJah PC Specs
    SimeJah PC Specs
    MotherboardROG Crosshair VIII Extreme
    ProcessorRyzen 5950X
    Memory (part number)128 GB 3600mHz (G.Skill Ripjaws V F4-3600C16Q-128GVK)
    Graphics Card #1RTX 3090FE
    Graphics Card #2AMD Radeon R9 380
    Graphics Card #3(Nvidia GT710)
    Sound CardFocusrite Scaerlet 2i2 gen 2
    MonitorDell ultrasharp u3219q
    Storage #1PNY CS3040 M.2 4000 GB VNME (x2)
    Storage #2Crucial 500MX 2TB (x2)
    CPU CoolerBe Quiet dark rock pro 4
    CaseFractal design meshify 2
    Power SupplyPrime fanless TX700
    Keyboard Corsair K55 RGB
    Mouse Logitech MX vertical
    Headset Beyerdynamic DT 770 pro 80 Ohm
    Mouse Pad Coolermaster MP511
    Headset/Speakers Genelec 8010 (2x)
    OS Windows 11 and MacOS Big Sur (Dual boot)
    Accessory #1 Roland A49 keyboard
    Accessory #2 XLR Senheiser MKE600
    Accessory #3 Wireless phone charger
    Sep 2021
    3
    ROG Crosshair VIII Extreme - Bluetooth and Wifi not working
    So I got my ROG Crosshair VIII Extreme mobo about a month ago.
    Everything is working fine except 2 things;
    the Wifi and (more importantly) Bluetooth are not working.
    I already tried;
    - reconnecting the antenna (both ways)
    - resetting BIOS
    - Clearing CMOS
    - triple checked if the devices are enabled in BIOS
    - installing the drivers from ASUS website multiple times.
    - installing 3rd party drivers
    - installing legacy drivers
    - Installing a fresh copy of Windows 10
    - upgrading to windows 11
    It is noteworthy that when I try to run the driver installer all I get is a brief flashing of a CMD window. It does not seem like it's installing much, but I could be wrong here.
    Any help would be greatly appreciated.
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 Pro 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    396
    641
    You need these drivers for your ASUS ROG Crosshair VIII Extreme motherboard :
    [DRIVERS] AMD Chipset/SATA (3xx/4xx/5xx/TRX40)
    - AMD Chipset Drivers
    [DRIVERS] Intel Serial IO/Thunderbolt (3xx/4xx/5xx)
    - Intel Thunderbolt Drivers
    [DRIVERS] Intel Ethernet/WiFi/Bluetooth
    - Intel Ethernet Drivers (Drivers Only) :
    Drivers - I22x-V (2.5GbE)
    - Intel WiFi Drivers (Drivers Only)
    - Intel Bluetooth Drivers (Drivers Only)
    [DRIVERS] Marvell/Aquantia Ethernet
    - Marvell/Aquantia Ethernet Drivers (Drivers Only)
    [DRIVERS] Realtek USB Audio (MB | Intel 5xx/6xx & AMD 5xx/TRX40)
    You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC408x codec, so :
    You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS MB) Gen2 from the first post of the thread.
    Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
    SimeJah PC Specs
    Sep 2021
    3
    installation not succeeding...
    Quote Originally Posted by MoKiChU View Post
    [DRIVERS] MediaTek WiFi/Bluetooth
    - MediaTek WiFi Drivers (Drivers Only)
    - MediaTek Bluetooth Drivers (Drivers Only)
    You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS MB) from the first post of the thread.
    Thank you for sending these drivers (which are not listed on the asus motherboard page which I find both strange and disturbing.)
    Anyway.. I cannot seem to install these.. You mention the following; "Right click on "mtkbtfilter.inf" > Install > Wait for the message "The operation completed successfully" or for restart request"
    When I right click and select install I get a UAC prompt, I click continue, and... nothing happens. no message, no nothing.
    How can this be? Is there any other way to install it?
    Thank you!
    SimeJah PC Specs
    Sep 2021
    3
    Unhappy devices are not listed in Device manager
    Both devices you mentioned are not listed in Device manager. That is the whole problem. So I cannot do this technique.
    New ROGer Array
    Jul 2019
    6
    Quote Originally Posted by SimeJah View Post
    Hello, I have same MOBO.
    This board uses an Intel Wireless module, not Mediatek.
    You need to install Intel drivers. Maybe this is what is causing your problem....
Name:	Captura de pantalla 2021-10-09 135503.jpg
    Check this thread:
    https://rog.asus.com/forum/showthrea...WiFi-Bluetooth
Tags for this Thread
