GT-AXE11000 and wifi6
Saltgeek
I am wondering if anyone has wifi 6 working on your iPhone with the GT-AXE11000 router. What settings are you using?
Any advice on getting it to work?
Thanks
4 REPLIES 4
Saltgrass
Do you have some info that tells you the iPhone, even the 13 version, has Wi-Fi 6e?
If you are referring to Wi-Fi 6 then it should work on your 5Ghz radio just as you might expect.. I have a 10 and never had a problem with it..
Are you running your system with a Mesh node that does not have Ethernet Back Haul?
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
My understanding is the iPhone 13 has wifi 6e. their website says Wi‑Fi 6 (802.11ax) with 2x2 MIMO.
I do not have
Ethernet Back Haul turned on
Saltgrass
OK, maybe I am missing something. What in the following listing makes you believe it is capable of Wi-Fi 6e or a 6 GHz Wi-Fi radio? I do agree it does Wi-Fi 6 or Wi-Fi ax. It also seems Bluetooth 5.1 is related to the 6 GHZ capability and this one only does Bluetooth 5.0.
There have been discussions here regarding a Android phone, which I believe does 6e..
All models
5G (sub‑6 GHz and mmWave)7
Gigabit LTE with 4x4 MIMO and LAA7
Bluetooth 5.0 wireless technology
Ultra Wideband chip for spatial awareness8
NFC with reader mode
Express Cards with power reserve
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
Wifi 6 = use the upper end of the 5ghz band
this is not part of dual band with 2.4 and 5ghz = it is its own thing
wifi 6e = use the full 6ghz band
FYI, routers that support wifi 6e are rare at this time.
The are lots of routers claiming tri-band but they do not go into the 6ghz range.
Most current routers claiming tri-band only support wifi 6 as the 3rd band
