Results 1 to 3 of 3
    New ROGer Array
    Jun 2021
    18
    Fiber / Fibre to Home
    My ISP is upgrading their infrastructure and running fibre into everbody's home.
    Am I dreaming, or is did I read somewhere that you can plug the ISP fibre connection straight into the AX-11000? ISP connection will be SC I believe, so perhaps it was a SC to RJ45 conneciton? Might require some sort of transceiver?
    Today, my AX-11000 still goes through the ISP Modem, but my PPPoE credentials are used on the Asus, so it does get a public IP and speeds are quite good. I am just wondering if soon I will be able to eliminate the ISP modem entirely.
    ROG Guru: Orange Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    463
    You probably need to check with your ISP. I believe fiber has some type of device outside the house which converts it to what you need.
    You may be able to get some info by just searching the Web for fiber installs.
    You don't mention the speed of the new connection. If it is higher than 1 Gbs, there is some doubt if the 2.5 Gbs LAN port can do a WAN speed of higher than 1 Gbs. You might be able to answer that question.
    New ROGer Array
    Jun 2021
    18
    The fastest package available to me would be 1.5 Gbps down / 940 Mbps up.
    I guess I'll find out soon enough
