MCE enabled vs auto differences at default settings
Nugisrott
So I would like to know if there is any difference how core ratio, voltage etc plays out when MCE is enabled vs set at ,,Auto" ?
Currently iv observed that in either case Intel specs seem to be used.
The board is Z490-F
Thanks!
Silent_Scone
Super Moderator
Hello,
1. Disabled will leave the CPU to operate within Intel's power envelope.
2. Enabled allows the the CPU to max out current limits, meaning the user doesn't need to set these power constraints in tweaker settings manually.
3. Auto, the board will by itself gauge the optimum settings taking into account the CPU's potential, thermal limitations and performance.
Nugisrott
**3. Auto, the board will by itself gauge the optimum settings taking into account the CPU's potential, thermal limitations and performance.**
Understood, but why do I not see any difference how cpu behaves when choosing ,,Auto" option -it most defenitely follows Intel Turbo boost specs.
