Results 1 to 8 of 8
    ROG Enthusiast Array omeggga's Avatar
    Jul 2018
    33
    Possible RAM problem? G752VSK
    So my wifi card is pretty heck, so I bought a new one, the new one being an intel 9260. I install it, it works, but pc starts acting weird. Loading things crashes the cursor entirely sometimes, reinstalling windows 10 didn't help, so I slot the old one back in and reinstall, pc is still acting a bit crazy.
    Turns out, on my way out of first installing the 9260 I took the RAM cards beneath the keyboard and moved them to the back so that if I upgrade, it'd be easier.
    Recently I learned that a motherboard has certain ram slots it "preffers". Is that what's happening here? Do i need to jam these sticks back on the slots under the KB?
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    795
    On the ASUS G752VSK Bank 0 and Bank 2 are on the keyboard-side and Bank 1 and Bank 3 are on the back-side. My G752VSK came with a single 16GB RAM stick installed in the Bank 0 slot.
    I surmise you must have at least Bank 0 slot filled to operate this motherboard.
    Install your RAM in the two keyboard-side slots first, then install additional RAM in the back-side slots.
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    Jul 2018
    33
    Yeah when I did the card swap I moved them from 0 and 2 to 1 and 3. So like, the motherboard gives prefferential treatment to 0 and 2 or like, how's that work exactly? 'lil confused here.
    Also swapped the cards, gonna do some testing and fiddling but so far it's running MUUUUCH better.
    Nov 2012
    75
    795
    The G752VSK has a dual channel processor, Bank 0 slot and Bank 2 slot are linked and support one channel, Bank 1 slot and Bank 3 slot are linked and support the other channel. The dual channel processor can work with just one channel but works better with memory in both channels.
    Jul 2018
    33
    I see, also, what do you recommend for undervolting? XTU ot throttlestop? The motherboard doesn't seem to have a setting to lower voltage in it.
    Nov 2012
    75
    795
    Since you have to remove ROG Gaming Center to get either XTU or Throttlestop to work properly, I prefer to use the ROG Gaming Center version 2.7.1 and not mess with any settings. I do have ASUS Turbo Gear Config version 1.0.3 installed.
  7. #7
    Jul 2018
    33
    Quote Originally Posted by jdfrench3 View Post
    ROG Gaming Center didn't allow me to undervolt...
  8. #8
    ROG Guru: Green Belt Array
    Feb 2019
    129
    692
    My G752VY came with one in the user service area and the other under the keyboard. I yanked what was in there and put 4X 16 GB Gskill ripjaws. Works great.
