Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    New ROGer Array GoldenVenom PC Specs
    MotherboardAsus PIME x570-PRO
    ProcessorAMD Ryzen 5800x
    Memory (part number)Corsair CMH64GX4M4D3600C18
    Graphics Card #1Asus ROG Strix 3090 White OC
    MonitorLG38GN950, 2x Asus TUF VG24VQ
    Storage #1Samsung Evo 980 & Evo 970 1TB
    Storage #21,5TB Toshiba HDD, 512GB Kingston SSD, 500GB Samsung Evo 850
    CPU CoolerCorsair Capellix H150i
    CaseLian Li Dynamic XL White ROG certified
    Power SupplyBe Quiet! Straight Power 1000W
    Keyboard Asus ROG Claymore II
    Mouse Razer Naga Left-Handed 2020
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad Corsair MM700
    Headset/Speakers Galaxy Buds +
    OS Windows 11
    Network RouterFritz!Box 7530AX
    Oct 2021
    4
    Question Asus Claymore II Caps-Lock stuck
    Hi, my CapsLock reversed sometimes. No matter wheather i hit it or not. This onlys occures in Wireless mode, no problems if wired.
    I have seriuosly no idea how to reproduce. While i'm tiping this my caps reversed again.
    Now: LED on = no caps, LED off = caps.
    I tried everything Software sided like changing keyboard setting etc, and even reseted via FN+ESC, Shift + Caps, long press Caps, Ctrl+shift+caps.. So i'm assuming, that's firmware based? Because no problems at wired mode.
    Got this problem on Win10 assuming on Win11 it gets fixed but no, no software problem. Even a clean install of 11 won't fix it.
    Any advice here?
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    158
    2,018
    Do you have Armoury Crate installed? What firmware are you on?
    OS Windows 11
    Oct 2021
    4
    Quote Originally Posted by MasterC@ROG View Post
    Thank you for your reply. my bad, should have added this before: A.C. v.4.2.5.0
    Keyboard: 12.21.17
    keyfield: 1.00.14
    Dongle: 1.00.12
    If relevant in Device-Kit (in Update Center) the displayed version is 2.1.1.3
    OS Windows 11
    Oct 2021
    4
    Quote Originally Posted by GoldenVenom View Post
    Keyboard: 12.21.17
    keyfield: 1.00.14
    Dongle: 1.00.12
    Good new:
    Armoury Crate v4.2.12.0 reduced the come up of this issue. Instead of dayli, it now comes just every 2 or 3 days.
    ROG Member Array
    Oct 2015
    13
    Good new:
    My workaround is to off and on the keyboard when on wireless.
    Running on:
    Item Version
    Armoury Crate UWP App 4.2.12.0
    ROG Live Service 1.2.18.0
    AURA Service (Lighting Service) 3.05.18
    Armoury Crate lite service 4.2.12
    ASUS AIOFan HAL 1.1.40.0
    ASUS AURA Extension Card HAL 1.1.0.11
    ASUS AURA Motherboard HAL 1.2.3.1
    ASUS Keyboard HAL 1.01.48
    AacVGA 0.0.4.3
    KingstonDram 1.1.8
    AURA DRAM Component 1.1.14
    ENE RGB HAL 1.1.37.0
    ENE_EHD_M2_HAL 1.0.9.1
    PHISON HAL 1.0.9.0
    Patriot Viper DRAM RGB 1.0.9.2
    Patriot Viper M2 SSD RGB 1.0.6.4
    Universal Holtek RGB DRAM 1.0.0.2
    WD_BLACK AN1500 1.0.13.0
    OS Windows 11
    Oct 2021
    4
    Lightbulb
    Quote Originally Posted by cainhs View Post
    Running on:
    Item Version
    AacVGA 0.0.4.3
    KingstonDram 1.1.8
    PHISON HAL 1.0.9.0
    Jup, as mentioned every 2-3 days the issue occures and then i have to turn the keyboard off and on or plug the usb-c in its like "resync" when plugging in
  7. #7
    New ROGer Array
    Dec 2021
    2
    Same issue
    I have the same issue. CAPS LOCK LIGHT is showing reverse but I have noticed other issues.
    If you have NUMPAD off pressing CAPS LOCK will force it to turn on, same with the scroll lock.
    Turning it ON and OFF solves it but still it's annoying to experience this on an expensive keyboard!
  8. #8
    Aug 2014
    158
    2,018
    Claymore II Firmware (80%) v20.12.01 just released, please update. It should be resolved.
  9. #9
    ROG Member Array marksmith85 PC Specs
    MotherboardAsus ROG Strix X570-E Gaming
    ProcessorAMD Ryzen 9 5900x
    Memory (part number)Crucial Ballistix RGB 32 GB (2 x 16 GB) DDR4-3600 CL16
    Graphics Card #1Asus Strix 3080ti OC
    MonitorAcer Predator x34p
    Storage #1Seagate 530 500GB
    Storage #2Seagate 530 2TB
    CPU CoolerAsus ROG RYUJIN II 360
    CaseCorsair 5000d Airflow
    Power SupplyCorsair 1000RMx
    Keyboard Asus Claymore 2
    Mouse Logitech G403
    Headset Logitech G935
    Mouse Pad Logitech G440
    Headset/Speakers Logitech Z130 5 W 2.0 Channel Speakers
    OS Windows 11 Pro
    Network RouterTP Link Archer A7
    Accessory #1 7x Phanteks PH-F120T30 67 CFM 120 mm Fan
    Jan 2018
    18
    Hi afraid I am still getting that same issue as of today.
    Whats even stranger is if press number lock on\off and then go to turn caps lock on\off it turns off numlock instead.
    Same if I turn caps lock on/off and then press num lock it will continue to turn off caps lock.
    Only way to resolve is to turn the keyboard on\off from the switch at the back......
  10. #10
    ROG Guru: Yellow Belt Array TSportM PC Specs
    TSportM PC Specs
    Laptop (Model)ASUS ROG G751JY
    MotherboardZ690 Maximus extreme
    Processor12900k@5.400mhz
    Memory (part number)gskill ddr4 Royal gold 3600@3800
    Graphics Card #1Geforce RTX 3090@2100mhz
    Sound Cardonboard
    Monitor32:9 samsung C49H/ 2X asus 27 / 1X LG34
    Storage #1crucual 1 tb nme 4.0
    Storage #24xraid0 1tb wd black / 2Xsamsung SSD 850evo 2TB
    CPU CoolerCustom LOOP
    CaseCorsair 1000D
    Power SupplyCorsair 1500i
    Keyboard ASUS Claymore II
    Mouse ASUS Chakram
    Headset AStro A50
    Mouse Pad ASUS SHEATH
    Headset/Speakers Logitech Z5500 digital
    OS windows 11 pro 64bit
    Network Routerasus GT - AX11000
    TSportM's Avatar
    Apr 2015
    23
    216
    have the same problem, thing is the update you say is not available for me
    GMS1Corsair 1000D|ROGZ690 Maximus extreme i9 12900k@5400@ 1.4 custom loop|32gDominator-DDR5 6000mhz-Geforce RTX 3090@2150mhz-powered by corsair 1600i
    GMS2Corsair 1000D|ROGRampageViEE-i910980XE@5.1ghz@1.36v custom loop|32gbGSKILLRoyalGold-DDR4-Geforce RTX 3090@2100mhz
    @powerby Corsair 1500i ||| Steam - MDK_pt | uplay -»MDK-pt| battlenet -» MDKpt#21176 | origin -» MDK_PRT| youtube: Click here
Tags for this Thread
