Results 1 to 1 of 1
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus XI Extreme (BIOS 1503 to 1903)
    Processor9900K @ 5.1 Ghz w EK Velocity
    Memory (part number)32 GB -Dominator Platinum 3200 Mhz CAS 16
    Graphics Card #1Evga RTX 3080Ti FTW3 Ultra w FC EKWB
    Sound CardOnboard Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 970 Pro 512G M.2 NNMe
    Storage #2Samsung 860 Pro 512G & 256G
    CPU CoolerEK Supremacy Copper w Nickel Plating
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W10 HP x64 - 21H1
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    37
    309
    Maximus XI E and M.2_1 / M.2_2 with PCI-E x16_1 Question
    Folks
    I presently have a single Nvme M.2 stick in M.2_1 slot and still can maintain x16 speed in my PCI-E_1 Slot (GPU)....
    Question, if I add a 2nd M.2 Drive to my other onboard M.2_2 location, will my GPU (3080 Ti FTW3) continue to run at x16 speed?
    Im not using the DIMM slot for M.2 Drives at all and not planning on it.....I have a Samsung 970 Pro 512G for boot drive and would like to add a 2nd M.2 Drive to that vacant slot M.2_2 for games, likely a 1TB.....
