10-16-2021 07:28 AM - last edited 2 weeks ago by ROGBot
10-16-2021 08:51 AM
10-16-2021 10:05 AM
Saltgrass wrote:
I don't have that exact board, but have you verified installing the RTX video card does disable the onboard video?
You comment about the problem going away after boots may indicate you could try turning off Fast Startup in Windows in case the hibernation file it creates is involved.
You are confident your power supply is large enough for whichever RTX card you have?
I have no way of knowing if the Keyboard power problem is involved but you might try changing them out..
I would not think the Bios version was involved..
Is this a new build?
10-16-2021 09:32 AM
KonEv wrote:
Hello!
I have motheboard ROG STRIX Z590-A GAMING WIFI (BIOS 1007) with Intel 11900 (without K). I have big problem with stability of power on. The typical and biggest problem when Q-Led on the mobo stay light white after boot, but my discrete RTX card working well and Win10 doesn't see any problems with the hardware. After hot restart this problem may gone out and white Q-led became switched off. In this case my computer is working fine without any problems till manual power off.
If I have disconnected (extracted) external video card and use Display Port to connect monitor directly to the motheboard, I see same issue. If white Q-led is staying switched on I have black monitor and nothing appeared. So, the problem is not in NVIDIA card. After one or several reboot the problem*typically*is gone.
Another problem - when computer has lost USB keyboard OR mouse during boot. So, I always able to make Switch Off from Windows.
Plus sometime I can not call BIOS by using F2 or Del keys and Win10 start window appear. I have to reboot usually 2-7 times after cold Power On to have fine working computer.
*I already had tried to use BIOS 0902, update Intel ME drivers, Intel VGA drivers, reset BIOS to default etc. MemTest86 pass without errors. Also I changed monitor. :(:(:(
*Any ideas?
Thanks!
10-16-2021 09:54 AM
10-16-2021 10:05 AM
KonEv wrote:
Thank you for your answer!
Unfortunately, I have same problem with white Q-led without installed discrete NVIDIA card in my computer.Â*My motheboard has own Display Port and HDMI. When I connect a Monitor directly to Motheboard, sometime I have white Q-led and black monitor... If I see white Q-led on, I have to reboot several times... I tried Swith On / Switch off two different monitors before boot with different cables. The problem inside of mobo or(and) CPU
10-16-2021 10:43 AM
MrAgapiGC wrote:
It will feel odd my reply. but avoid that the monitor goes to sleep. is almost instant. play with the osd in the monitor when the you are turning on the pc
10-23-2021 07:00 AM
