Nate152 wrote:
Hi rolani4
Those voltages are a bit high, would set VCCIO and System Agent voltage manually to 1.25v and see how it goes.
Thing is 1.25v may not work for Gear 1 @ 3733Mhz. More likely it will work for 11 gen i9 CPUs but not i7 11700K coz its memory controller requires more voltage (same applies to vcore voltage for 11700K) because of worse silicon. i7 just need more juice for stable run. 1.25v SA\Mem OC it's more Gear 1 @ 3600Mhz voltage. (system may boot Gear 1 @ 3733Mhz but 90% it will be unstable under stress load with this voltage).
Meanwhile 1.25v SA\Mem OC can be sufficent for Gear 2 @ somewhere around 4533Mhz.
