Results 1 to 3 of 3
    ROG Enthusiast Array Englishman.Xperia PC Specs
    MotherboardASUS RoG Strix B450-E Gaming
    ProcessorAMD Ryen2700X
    Memory (part number)Corsair 16Gb DDR3200 LPX
    Graphics Card #1ASUS RoG Strix RX480 OC
    MonitorASUS RoG XG27VQ
    Storage #1Corsair MP510 480gb
    Storage #2AMD R7 240Gb SSD
    CPU CoolerAMD Wraith Prism
    CaseCorsair Obsidian 450D
    Power SupplyASUS RoG 750Watt
    Keyboard ASUS RoG Strix Flare
    Mouse ASUS RoG Gladius II Origin
    Mouse Pad ASUS RoG Sheath
    Headset/Speakers Logitech 5.1
    OS Windows 10
    Network RouterASUS Lyra Mini
    Feb 2021
    33
    Ryzen 2700X with 3200Mhz 16gb or 32gb
    Hi to all great people out there. I have one question that I would like to get help or feedback.
    I'm looking to upgrade my ram to 32gb, mostly due to video editing. Well.. it does run super fine with 16gb but since I'm going to spend some cash, I might as well as get more.
    The problem is:
    I have a 2700X and a Strix B450 E Gaming, the QVL is somewhat limited. Even worst, my current Corsair ram sticks are on the QVL and they do give me some problems.
    The BUG:
    When I play DirectX 11 games, sometimes my pc crashes completely, no BSOD just a gray screen forcing me to reboot with the button, also, the DRAM light on the board goes on.
    If I stress test the system, nothing happens, AIDA, Prime, Memtest for hours. Zero problems. DirectX9, 12 or vulkan games also goes on flawlessly. Its just DirectX 11 games.
    I have the Ram on 3200Mhz CL16, I've tried Ryzen DRAM calculator on SAFE, loosen timings myself, increasing voltage to 1.45 to no avail.
    I decided to buy the G.Skill as most people say its the best for Ryzen but what do you guys think?
    32Gb (problably dual rank) and hope it does the 3200?
    https://www.gskill.com/product/165/1...00C16D-32GTZRX
    Stick with 16Gb and have 3200?
    https://www.gskill.com/product/165/1...00C14D-16GTZRX
    Thanks
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Buy from a shop that accepts returns, that's my advice. Zen 1 chips just struggle with memory and in my experience I sometimes found stability at like 2933 on a 3200 kit. If you need the extra capacity you might just have to settle for a lower speed unless you want to do days of tuning and testing.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,252
    Maybe use this QVL for 2000 series. I know it's for 3000 series and higher, but better than nothing to sus out what might work, if you want to look at others apart from g.skill
    https://www.amd.com/en/products/ryzen-compatible-memory
    The 2000 series memory controller may stuggle with 4xRAM, suggest 2xRAM to hit memory size you want and maybe G.skill Neo branded.
    Might find this tool helpful as well
    https://www.gskill.com/configurator
