rog chakram not visible in armory crate
eduardo_labrin
Hello I don't know when the mouse was updated, but now it does not display in armory, I uninstalled the driver and the application updated it, it does not display in wired/wireless. :mad:
https://prnt.sc/1y2ta3l
97 REPLIES 97
dansalsig
i've the same problem, updated the version HTML 2.13.07 and now can't view options for mouse.
Nate152
Hey guys,
Tell us a little more.
First thing I'd do is make sure you have the latest bios for your motherboard with all drivers and windows fully updated. You need windows 10 (1709 or later), I'm on windows 11 and everything is working fine with my ROG Chakram Core.
After clicking Check Update for the firmware, it should show this.
Click the picture to make it bigger.
90596
Nate152 wrote:
Hey guys,
90596
Hi Nate,
check your indications and I have the latest versions in armory create. update windows but the problem continues, I have Windows 10 version 21H2
90707
90708
Nate152
Strange,
Is your ROG Chakram synced with any devices?
If so, unsync it and see if it shows.
90709
90711
i have the same problem and i can´t change the buttoms of the mouse, is really annoying
Nate152 wrote:
Strange,
90709
90711
ROG Chakram only synced my PC, and unsync aura but the problem remains
90975
90976
I have these versions installed for ROG Chakram
90977
Hi guys, I have the exact same problem with a ROG Keris wireless, everything is working fine with armoury crate except the device control screen, I get a black screen
when selecting the device, so the only way I have to change DPI is manually tweaking with the fly wheel and color change is only possible with Aura Sync on dongle mode, once I switch to bluetooth the changes are gone, I have updated everything, I am using a ROG Zephyrus G14 2021.
balanzaurio
Hello I just Bought a chakram mouse
but when I try to open armory crate and start configuring the buttons armory crate just shows me a black screen, it doesn't load anything could you help me with this?
I already tried reinstalling armory crate, Uninstalling and installing aura synch , using armory crate without aura synch but nothing seems to be working
I will share you some of my information
My laptop is an asus strix G512LW.311
intel core i7 10750h cpu @ 2.60ghz
rtx 2070
16 gb in ram
Chakram driver version 2.1.1.3
Kit aura 2020210
hal 2.13.07
html Ver 2.13.07
SDK 2.01.07
firmware 13.11.33
Armory crate 4.2.12.0
I hope this helps
same problem, i can't change the buttons, anything.... please help....
Laptop: Asus Tuf FX505GT
