DSL-AX82U Hard reset
TrebleTA
I would like to know the correct way to hard reset my AX82U.
Also a bit more info for the router ui reset.
To hard reset I read switch off the router hold the wps, till lights go out the push power button, what power button, well it's a switch, so do I switch it off and on again.
A hard reset will clear all NVRam?
The router Ui has reset but has a option, what's the difference, as, "Initialize all the settings, and clear all the data log for AiProtection, Traffic Analyzer, and Web History" should that not be in the default? Just re initialize?
Oh then there is the reset button!
Thanks
39 REPLIES 39
STARRAIN_ROG
Customer Service Agent
Hi TrebleTA,
Please refer to the following link for hard factory reset on DSL-AX82U.
https://www.asus.com/support/FAQ/1039078
Hard factory reset and router UI reset ("Initialize..." option checked) both would clear nvram. If you cannot access router UI, please do hard factory reset.
Reset button or router UI reset option("Initialize..." option unchecked) both would only reset router settings to default.
Thanks but in the guide it says press power button, I have a switch, it mean when led gos off switch off then back on?
STARRAIN_ROG
Hi TrebleTA,
After power light goes off(with the power button on), please switch off and then on the power button to reboot the router.
Ok thanks, since I hard reset I have been getting a warning, I then soft reset and still get the below warning. Else everything seems fine
Nov  5 02:15:02 kernel: [59672.913794] ------------[ cut here ]------------
Nov 5 02:15:02 kernel: [59672.918431] WARNING: CPU: 0 PID: 31087 at net/sched/sch_htb.c:568 htb_qlen_notify+0x6c/0x70()
Nov 5 02:15:02 kernel: [59672.926964] Modules linked in: tdts_udbfw(O) init_addr( (null) - (null)), core_addr(bf1dd000 - bf1e1e70)
Nov 5 02:15:02 kernel: [59672.936735] tdts_udb(PO) init_addr( (null) - (null)), core_addr(bf33e000 - bf35dad4)
Nov 5 02:15:02 kernel: [59672.944850] tdts(PO) init_addr( (null) - (null)), core_addr(bf924000 - bf95f744)
Nov 5 02:15:02 kernel: [59672.952612] nf_nat_sip init_addr( (null) - (null)), core_addr(bf126000 - bf1276d0)
Nov 5 02:15:02 kernel: [59672.960574] nf_conntrack_sip init_addr( (null) - (null)), core_addr(bf0fc000 - bf0fedbc)
Nov 5 02:15:02 kernel: [59672.969035] nf_nat_h323 init_addr( (null) - (null)), core_addr(bf0f7000 - bf0f7f50)
Nov 5 02:15:02 kernel: [59672.977069] nf_conntrack_h323 init_addr( (null) - (null)), core_addr(bf0aa000 - bf0ad8d4)
Nov 5 02:15:02 kernel: [59672.985613] nf_nat_rtsp init_addr( (null) - (null)), core_addr(bf02e000 - bf02e830)
Nov 5 02:15:02 kernel: [59672.993637] nf_conntrack_rtsp init_addr( (null) - (null)), core_addr(bf02b000 - bf02c208)
Nov 5 02:15:02 kernel: [59673.002181] nf_nat_ftp init_addr( (null) - (null)), core_addr(bf010000 - bf010228)
Nov 5 02:15:02 kernel: [59673.010122] nf_conntrack_ftp init_addr( (null) - (null)), core_addr(bf005000 - bf005b88)
Nov 5 02:15:02 kernel: [59673.018577] thfsplus(O) init_addr( (null) - (null)), core_addr(bfcb9000 - bfcc5124)
Nov 5 02:15:02 kernel: [59673.026599] tntfs(PO) init_addr( (null) - (null)), core_addr(bfc32000 - bfc808fc)
Nov 5 02:15:02 kernel: [59673.034449] tfat(PO) init_addr( (null) - (null)), core_addr(bfbe3000 - bfc14f54)
Nov 5 02:15:02 kernel: [59673.042234] uas init_addr( (null) - (null)), core_addr(bfbdc000 - bfbddd48)
Nov 5 02:15:02 kernel: [59673.049559] usb_storage init_addr( (null) - (null)), core_addr(bfbc9000 - bfbcc820)
Nov 5 02:15:02 kernel: [59673.057586] sg init_addr( (null) - (null)), core_addr(bfbbe000 - bfbc1e80)
Nov 5 02:15:02 kernel: [59673.064830] sd_mod init_addr( (null) - (null)), core_addr(bfbb2000 - bfbb6840)
Nov 5 02:15:02 kernel: [59673.072430] scsi_mod init_addr( (null) - (null)), core_addr(bfb83000 - bfb91a54)
Nov 5 02:15:02 kernel: [59673.080193] cdc_mbim init_addr( (null) - (null)), core_addr(bfb7e000 - bfb7ea70)
Nov 5 02:15:02 kernel: [59673.087957] qmi_wwan init_addr( (null) - (null)), core_addr(bfb75000 - bfb75674)
Nov 5 02:15:02 kernel: [59673.095724] cdc_wdm init_addr( (null) - (null)), core_addr(bfb70000 - bfb715b8)
Nov 5 02:15:02 kernel: [59673.103411] cdc_ncm init_addr( (null) - (null)), core_addr(bfb68000 - bfb69fb8)
Nov 5 02:15:02 kernel: [59673.111097] rndis_host init_addr( (null) - (null)), core_addr(bfb63000 - bfb63b0c)
Nov 5 02:15:02 kernel: [59673.119029] cdc_ether init_addr( (null) - (null)), core_addr(bfb5f000 - bfb5f77c)
Nov 5 02:15:02 kernel: [59673.126881] ax88179_178a init_addr( (null) - (null)), core_addr(bfb57000 - bfb59544)
Nov 5 02:15:02 kernel: [59673.134989] asix init_addr( (null) - (null)), core_addr(bfb4e000 - bfb50510)
Nov 5 02:15:02 kernel: [59673.142406] libphy init_addr( (null) - (null)), core_addr(bfb43000 - bfb45f84)
Nov 5 02:15:02 kernel: [59673.149989] cdc_acm init_addr( (null) - (null)), core_addr(bfb3a000 - bfb3c1fc)
Nov 5 02:15:02 kernel: [59673.157669] usbnet init_addr( (null) - (null)), core_addr(bfb30000 - bfb32ecc)
Nov 5 02:15:02 kernel: [59673.165255] mii init_addr( (null) - (null)), core_addr(bfb2c000 - bfb2c9e4)
Nov 5 02:15:02 kernel: [59673.172583] ohci_pci init_addr( (null) - (null)), core_addr(bfb28000 - bfb281f4)
Nov 5 02:15:02 kernel: [59673.180342] ohci_platform init_addr( (null) - (null)), core_addr(bfb24000 - bfb246c0)
Nov 5 02:15:02 kernel: [59673.188538] ohci_hcd init_addr( (null) - (null)), core_addr(bfb19000 - bfb1db58)
Nov 5 02:15:02 kernel: [59673.196295] ehci_pci init_addr( (null) - (null)), core_addr(bfb15000 - bfb15584)
Nov 5 02:15:02 kernel: [59673.204055] ehci_platform init_addr( (null) - (null)), core_addr(bfb10000 - bfb1073c)
Nov 5 02:15:02 kernel: [59673.212249] ehci_hcd init_addr( (null) - (null)), core_addr(bfb03000 - bfb0a224)
Nov 5 02:15:02 kernel: [59673.220010] xhci_pci init_addr( (null) - (null)), core_addr(bfaff000 - bfaff59c)
Nov 5 02:15:02 kernel: [59673.227777] xhci_plat_hcd init_addr( (null) - (null)), core_addr(bfafb000 - bfafb4a0)
Nov 5 02:15:02 kernel: [59673.235974] xhci_hcd init_addr( (null) - (null)), core_addr(bfadf000 - bfaee234)
Nov 5 02:15:02 kernel: [59673.243752] bcm_usb init_addr( (null) - (null)), core_addr(bfada000 - bfada0b8)
Nov 5 02:15:02 kernel: [59673.251426] usbcore init_addr( (null) - (null)), core_addr(bfaad000 - bfac2250)
Nov 5 02:15:02 kernel: [59673.259103] usb_common init_addr( (null) - (null)), core_addr(bfaa9000 - bfaa9170)
Nov 5 02:15:02 kernel: [59673.267041] dhd init_addr( (null) - (null)), core_addr(bf9b9000 - bfa36d28)
Nov 5 02:15:03 kernel: [59673.274374] wl(P) init_addr( (null) - (null)), core_addr(bf37b000 - bf658280)
Nov 5 02:15:03 kernel: [59673.281871] dpsta(P) init_addr( (null) - (null)), core_addr(bf339000 - bf33b6f0)
Nov 5 02:15:03 kernel: [59673.289639] cfg80211 init_addr( (null) - (null)), core_addr(bf2ff000 - bf321348)
Nov 5 02:15:03 kernel: [59673.297398] igs(P) init_addr( (null) - (null)), core_addr(bf2f6000 - bf2f8ed4)
Nov 5 02:15:03 kernel: [59673.304986] emf(P) init_addr( (null) - (null)), core_addr(bf2ee000 - bf2f0740)
Nov 5 02:15:03 kernel: [59673.312570] hnd init_addr( (null) - (null)), core_addr(bf289000 - bf2b46b0)
Nov 5 02:15:03 kernel: [59673.319896] otp(P) init_addr( (null) - (null)), core_addr(bf285000 - bf285504)
Nov 5 02:15:03 kernel: [59673.327498] bcm_thermal init_addr( (null) - (null)), core_addr(bf280000 - bf2807b4)
Nov 5 02:15:03 kernel: [59673.335528] pwrmngtd(P) init_addr( (null) - (null)), core_addr(bf27c000 - bf27c480)
Nov 5 02:15:03 kernel: [59673.343548] bcm_pcie_hcd init_addr( (null) - (null)), core_addr(bf26f000 - bf273fb4)
Nov 5 02:15:03 kernel: [59673.351662] bcmmcast init_addr( (null) - (null)), core_addr(bf25b000 - bf26452c)
Nov 5 02:15:03 kernel: [59673.359420] nciTMSkmod(P) init_addr( (null) - (null)), core_addr(bf1f6000 - bf21f144)
Nov 5 02:15:03 kernel: [59673.367625] nciexLinuxETH(P) init_addr( (null) - (null)), core_addr(bf1ee000 - bf1ef9b4)
Nov 5 02:15:03 kernel: [59673.376081] nciLservices(P) init_addr( (null) - (null)), core_addr(bf1e8000 - bf1e883c)
Nov 5 02:15:03 kernel: [59673.384451] bcm_enet init_addr( (null) - (null)), core_addr(bf1bb000 - bf1d185c)
Nov 5 02:15:03 kernel: [59673.392211] adsldd(P) init_addr( (null) - (null)), core_addr(bf12d000 - bf1636dc)
Nov 5 02:15:03 kernel: [59673.400060] bcmxtmcfg(P) init_addr( (null) - (null)), core_addr(bf10e000 - bf119d0c)
Nov 5 02:15:03 kernel: [59673.408224] bcmxtmrtdrv init_addr( (null) - (null)), core_addr(bf102000 - bf106cdc)
Nov 5 02:15:03 kernel: [59673.416265] archer(P) init_addr( (null) - (null)), core_addr(bf0ca000 - bf0e4064)
Nov 5 02:15:03 kernel: [59673.424114] cmdlist(P) init_addr( (null) - (null)), core_addr(bf0b4000 - bf0bf1dc)
Nov 5 02:15:03 kernel: [59673.432054] pktflow(P) init_addr( (null) - (null)), core_addr(bf06e000 - bf0934a4)
Nov 5 02:15:03 kernel: [59673.439988] bcm_ingqos(P) init_addr( (null) - (null)), core_addr(bf034000 - bf037ac8)
Nov 5 02:15:03 kernel: [59673.448189] chipinfo(P) init_addr( (null) - (null)), core_addr(bf030000 - bf030104)
Nov 5 02:15:03 kernel: [59673.456209] bcmvlan(P) init_addr( (null) - (null)), core_addr(bf012000 - bf01fa10)
Nov 5 02:15:03 kernel: [59673.464144] bcmlibs(P) init_addr( (null) - (null)), core_addr(bf008000 - bf00a598)
Nov 5 02:15:03 kernel: [59673.472078] wlcsm(P) init_addr( (null) - (null)), core_addr(bf000000 - bf0011d4)
Nov 5 02:15:03 kernel: [59673.479842] [last unloaded: ip6table_nat]
Nov 5 02:15:03 kernel: [59673.483950] CPU: 0 PID: 31087 Comm: tc Tainted: P W O 4.1.52 #2
Nov 5 02:15:03 kernel: [59673.490816] Hardware name: Generic DT based system
Nov 5 02:15:03 kernel: [59673.495622] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
Nov 5 02:15:03 kernel: [59673.503365] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Nov 5 02:15:03 kernel: [59673.510584] [] (dump_stack) from [] (warn_slowpath_common+0x80/0xb0)
Nov 5 02:15:03 kernel: [59673.518669] [] (warn_slowpath_common) from [] (warn_slowpath_null+0x1c/0x24)
Nov 5 02:15:03 kernel: [59673.527449] [] (warn_slowpath_null) from [] (htb_qlen_notify+0x6c/0x70)
Nov 5 02:15:03 kernel: [59673.535797] [] (htb_qlen_notify) from [] (qdisc_tree_reduce_backlog+0x88/0x11c)
Nov 5 02:15:03 kernel: [59673.544837] [] (qdisc_tree_reduce_backlog) from [] (htb_delete+0x19c/0x2d0)
Nov 5 02:15:03 kernel: [59673.553527] [] (htb_delete) from [] (tc_ctl_tclass+0x2c8/0x308)
Nov 5 02:15:03 kernel: [59673.561179] [] (tc_ctl_tclass) from [] (rtnetlink_rcv_msg+0x94/0x224)
Nov 5 02:15:03 kernel: [59673.569352] [] (rtnetlink_rcv_msg) from [] (netlink_rcv_skb+0xb4/0xd8)
Nov 5 02:15:03 kernel: [59673.577612] [] (netlink_rcv_skb) from [] (netlink_unicast+0x154/0x204)
Nov 5 02:15:03 kernel: [59673.585870] [] (netlink_unicast) from [] (netlink_sendmsg+0x2cc/0x354)
Nov 5 02:15:03 kernel: [59673.594129] [] (netlink_sendmsg) from [] (sock_sendmsg+0x14/0x24)
Nov 5 02:15:03 kernel: [59673.601953] [] (sock_sendmsg) from [] (___sys_sendmsg+0x1cc/0x1d4)
Nov 5 02:15:03 kernel: [59673.609864] [] (___sys_sendmsg) from [] (__sys_sendmsg+0x3c/0x68)
Nov 5 02:15:03 kernel: [59673.617688] [] (__sys_sendmsg) from [] (ret_fast_syscall+0x0/0x3c)
Nov 5 02:15:03 kernel: [59673.625878] ---[ end trace 88b0470bc2ba5e07 ]---
Anything to worrie about??
STARRAIN_ROG
Hi TrebleTA,
Did the warning only appear once after reset or always appear?
Did you do soft reset through router UI reset ("Initialize..." option checked)?
@starrain@rog. Thank you for all the support.
Right, on wednesday I did a hard reset and then noticed the above error also i was getting a routing error for a ipv6 address yet ipv6 is off was strange.
So I then did a soft reset, via the ui, no tick. After that all looked fine, 24hrs after I then sent feedback as all looked good and no harming in sending I think.
Then last night I see the above error two of them and think I'll ask. I will post the first warning that I got here I then got the seconed above right after. Nothing since.
I reset as think I had done it wrong when I did before in my other post.
Nov  5 02:15:01 kernel: [59672.197174] ------------[ cut here ]------------
Nov 5 02:15:01 kernel: [59672.201836] WARNING: CPU: 0 PID: 31087 at net/sched/sch_htb.c:568 htb_qlen_notify+0x6c/0x70()
Nov 5 02:15:01 kernel: [59672.210380] Modules linked in: tdts_udbfw(O) init_addr( (null) - (null)), core_addr(bf1dd000 - bf1e1e70)
Nov 5 02:15:01 kernel: [59672.220163] tdts_udb(PO) init_addr( (null) - (null)), core_addr(bf33e000 - bf35dad4)
Nov 5 02:15:01 kernel: [59672.228282] tdts(PO) init_addr( (null) - (null)), core_addr(bf924000 - bf95f744)
Nov 5 02:15:01 kernel: [59672.236040] nf_nat_sip init_addr( (null) - (null)), core_addr(bf126000 - bf1276d0)
Nov 5 02:15:01 kernel: [59672.243986] nf_conntrack_sip init_addr( (null) - (null)), core_addr(bf0fc000 - bf0fedbc)
Nov 5 02:15:01 kernel: [59672.252444] nf_nat_h323 init_addr( (null) - (null)), core_addr(bf0f7000 - bf0f7f50)
Nov 5 02:15:02 kernel: [59672.260467] nf_conntrack_h323 init_addr( (null) - (null)), core_addr(bf0aa000 - bf0ad8d4)
Nov 5 02:15:02 kernel: [59672.269014] nf_nat_rtsp init_addr( (null) - (null)), core_addr(bf02e000 - bf02e830)
Nov 5 02:15:02 kernel: [59672.277044] nf_conntrack_rtsp init_addr( (null) - (null)), core_addr(bf02b000 - bf02c208)
Nov 5 02:15:02 kernel: [59672.285586] nf_nat_ftp init_addr( (null) - (null)), core_addr(bf010000 - bf010228)
Nov 5 02:15:02 kernel: [59672.293523] nf_conntrack_ftp init_addr( (null) - (null)), core_addr(bf005000 - bf005b88)
Nov 5 02:15:02 kernel: [59672.301977] thfsplus(O) init_addr( (null) - (null)), core_addr(bfcb9000 - bfcc5124)
Nov 5 02:15:02 kernel: [59672.309999] tntfs(PO) init_addr( (null) - (null)), core_addr(bfc32000 - bfc808fc)
Nov 5 02:15:02 kernel: [59672.317843] tfat(PO) init_addr( (null) - (null)), core_addr(bfbe3000 - bfc14f54)
Nov 5 02:15:02 kernel: [59672.325614] uas init_addr( (null) - (null)), core_addr(bfbdc000 - bfbddd48)
Nov 5 02:15:02 kernel: [59672.332942] usb_storage init_addr( (null) - (null)), core_addr(bfbc9000 - bfbcc820)
Nov 5 02:15:02 kernel: [59672.340970] sg init_addr( (null) - (null)), core_addr(bfbbe000 - bfbc1e80)
Nov 5 02:15:02 kernel: [59672.348207] sd_mod init_addr( (null) - (null)), core_addr(bfbb2000 - bfbb6840)
Nov 5 02:15:02 kernel: [59672.355795] scsi_mod init_addr( (null) - (null)), core_addr(bfb83000 - bfb91a54)
Nov 5 02:15:02 kernel: [59672.363553] cdc_mbim init_addr( (null) - (null)), core_addr(bfb7e000 - bfb7ea70)
Nov 5 02:15:02 kernel: [59672.371314] qmi_wwan init_addr( (null) - (null)), core_addr(bfb75000 - bfb75674)
Nov 5 02:15:02 kernel: [59672.379073] cdc_wdm init_addr( (null) - (null)), core_addr(bfb70000 - bfb715b8)
Nov 5 02:15:02 kernel: [59672.386746] cdc_ncm init_addr( (null) - (null)), core_addr(bfb68000 - bfb69fb8)
Nov 5 02:15:02 kernel: [59672.394452] rndis_host init_addr( (null) - (null)), core_addr(bfb63000 - bfb63b0c)
Nov 5 02:15:02 kernel: [59672.402409] cdc_ether init_addr( (null) - (null)), core_addr(bfb5f000 - bfb5f77c)
Nov 5 02:15:02 kernel: [59672.410256] ax88179_178a init_addr( (null) - (null)), core_addr(bfb57000 - bfb59544)
Nov 5 02:15:02 kernel: [59672.418367] asix init_addr( (null) - (null)), core_addr(bfb4e000 - bfb50510)
Nov 5 02:15:02 kernel: [59672.425777] libphy init_addr( (null) - (null)), core_addr(bfb43000 - bfb45f84)
Nov 5 02:15:02 kernel: [59672.433367] cdc_acm init_addr( (null) - (null)), core_addr(bfb3a000 - bfb3c1fc)
Nov 5 02:15:02 kernel: [59672.441038] usbnet init_addr( (null) - (null)), core_addr(bfb30000 - bfb32ecc)
Nov 5 02:15:02 kernel: [59672.448626] mii init_addr( (null) - (null)), core_addr(bfb2c000 - bfb2c9e4)
Nov 5 02:15:02 kernel: [59672.455948] ohci_pci init_addr( (null) - (null)), core_addr(bfb28000 - bfb281f4)
Nov 5 02:15:02 kernel: [59672.463714] ohci_platform init_addr( (null) - (null)), core_addr(bfb24000 - bfb246c0)
Nov 5 02:15:02 kernel: [59672.471909] ohci_hcd init_addr( (null) - (null)), core_addr(bfb19000 - bfb1db58)
Nov 5 02:15:02 kernel: [59672.479675] ehci_pci init_addr( (null) - (null)), core_addr(bfb15000 - bfb15584)
Nov 5 02:15:02 kernel: [59672.487432] ehci_platform init_addr( (null) - (null)), core_addr(bfb10000 - bfb1073c)
Nov 5 02:15:02 kernel: [59672.495627] ehci_hcd init_addr( (null) - (null)), core_addr(bfb03000 - bfb0a224)
Nov 5 02:15:02 kernel: [59672.503384] xhci_pci init_addr( (null) - (null)), core_addr(bfaff000 - bfaff59c)
Nov 5 02:15:02 kernel: [59672.511145] xhci_plat_hcd init_addr( (null) - (null)), core_addr(bfafb000 - bfafb4a0)
Nov 5 02:15:02 kernel: [59672.519338] xhci_hcd init_addr( (null) - (null)), core_addr(bfadf000 - bfaee234)
Nov 5 02:15:02 kernel: [59672.527102] bcm_usb init_addr( (null) - (null)), core_addr(bfada000 - bfada0b8)
Nov 5 02:15:02 kernel: [59672.534775] usbcore init_addr( (null) - (null)), core_addr(bfaad000 - bfac2250)
Nov 5 02:15:02 kernel: [59672.542453] usb_common init_addr( (null) - (null)), core_addr(bfaa9000 - bfaa9170)
Nov 5 02:15:02 kernel: [59672.550394] dhd init_addr( (null) - (null)), core_addr(bf9b9000 - bfa36d28)
Nov 5 02:15:02 kernel: [59672.557733] wl(P) init_addr( (null) - (null)), core_addr(bf37b000 - bf658280)
Nov 5 02:15:02 kernel: [59672.565234] dpsta(P) init_addr( (null) - (null)), core_addr(bf339000 - bf33b6f0)
Nov 5 02:15:02 kernel: [59672.572997] cfg80211 init_addr( (null) - (null)), core_addr(bf2ff000 - bf321348)
Nov 5 02:15:02 kernel: [59672.580755] igs(P) init_addr( (null) - (null)), core_addr(bf2f6000 - bf2f8ed4)
Nov 5 02:15:02 kernel: [59672.588344] emf(P) init_addr( (null) - (null)), core_addr(bf2ee000 - bf2f0740)
Nov 5 02:15:02 kernel: [59672.595926] hnd init_addr( (null) - (null)), core_addr(bf289000 - bf2b46b0)
Nov 5 02:15:02 kernel: [59672.603260] otp(P) init_addr( (null) - (null)), core_addr(bf285000 - bf285504)
Nov 5 02:15:02 kernel: [59672.610855] bcm_thermal init_addr( (null) - (null)), core_addr(bf280000 - bf2807b4)
Nov 5 02:15:02 kernel: [59672.618878] pwrmngtd(P) init_addr( (null) - (null)), core_addr(bf27c000 - bf27c480)
Nov 5 02:15:02 kernel: [59672.626897] bcm_pcie_hcd init_addr( (null) - (null)), core_addr(bf26f000 - bf273fb4)
Nov 5 02:15:02 kernel: [59672.635012] bcmmcast init_addr( (null) - (null)), core_addr(bf25b000 - bf26452c)
Nov 5 02:15:02 kernel: [59672.642781] nciTMSkmod(P) init_addr( (null) - (null)), core_addr(bf1f6000 - bf21f144)
Nov 5 02:15:02 kernel: [59672.650980] nciexLinuxETH(P) init_addr( (null) - (null)), core_addr(bf1ee000 - bf1ef9b4)
Nov 5 02:15:02 kernel: [59672.659436] nciLservices(P) init_addr( (null) - (null)), core_addr(bf1e8000 - bf1e883c)
Nov 5 02:15:02 kernel: [59672.667819] bcm_enet init_addr( (null) - (null)), core_addr(bf1bb000 - bf1d185c)
Nov 5 02:15:02 kernel: [59672.675581] adsldd(P) init_addr( (null) - (null)), core_addr(bf12d000 - bf1636dc)
Nov 5 02:15:02 kernel: [59672.683431] bcmxtmcfg(P) init_addr( (null) - (null)), core_addr(bf10e000 - bf119d0c)
Nov 5 02:15:02 kernel: [59672.691536] bcmxtmrtdrv init_addr( (null) - (null)), core_addr(bf102000 - bf106cdc)
Nov 5 02:15:02 kernel: [59672.699562] archer(P) init_addr( (null) - (null)), core_addr(bf0ca000 - bf0e4064)
Nov 5 02:15:02 kernel: [59672.707407] cmdlist(P) init_addr( (null) - (null)), core_addr(bf0b4000 - bf0bf1dc)
Nov 5 02:15:02 kernel: [59672.715342] pktflow(P) init_addr( (null) - (null)), core_addr(bf06e000 - bf0934a4)
Nov 5 02:15:02 kernel: [59672.723274] bcm_ingqos(P) init_addr( (null) - (null)), core_addr(bf034000 - bf037ac8)
Nov 5 02:15:02 kernel: [59672.731471] chipinfo(P) init_addr( (null) - (null)), core_addr(bf030000 - bf030104)
Nov 5 02:15:02 kernel: [59672.739491] bcmvlan(P) init_addr( (null) - (null)), core_addr(bf012000 - bf01fa10)
Nov 5 02:15:02 kernel: [59672.747427] bcmlibs(P) init_addr( (null) - (null)), core_addr(bf008000 - bf00a598)
Nov 5 02:15:02 kernel: [59672.755367] wlcsm(P) init_addr( (null) - (null)), core_addr(bf000000 - bf0011d4)
Nov 5 02:15:02 kernel: [59672.763136] [last unloaded: ip6table_nat]
Nov 5 02:15:02 kernel: [59672.767246] CPU: 0 PID: 31087 Comm: tc Tainted: P O 4.1.52 #2
Nov 5 02:15:02 kernel: [59672.774111] Hardware name: Generic DT based system
Nov 5 02:15:02 kernel: [59672.778917] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
Nov 5 02:15:02 kernel: [59672.786660] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Nov 5 02:15:02 kernel: [59672.793881] [] (dump_stack) from [] (warn_slowpath_common+0x80/0xb0)
Nov 5 02:15:02 kernel: [59672.801966] [] (warn_slowpath_common) from [] (warn_slowpath_null+0x1c/0x24)
Nov 5 02:15:02 kernel: [59672.810746] [] (warn_slowpath_null) from [] (htb_qlen_notify+0x6c/0x70)
Nov 5 02:15:02 kernel: [59672.819093] [] (htb_qlen_notify) from [] (qdisc_tree_reduce_backlog+0x88/0x11c)
Nov 5 02:15:02 kernel: [59672.828132] [] (qdisc_tree_reduce_backlog) from [] (htb_delete+0x19c/0x2d0)
Nov 5 02:15:02 kernel: [59672.836823] [] (htb_delete) from [] (tc_ctl_tclass+0x2c8/0x308)
Nov 5 02:15:02 kernel: [59672.844475] [] (tc_ctl_tclass) from [] (rtnetlink_rcv_msg+0x94/0x224)
Nov 5 02:15:02 kernel: [59672.852650] [] (rtnetlink_rcv_msg) from [] (netlink_rcv_skb+0xb4/0xd8)
Nov 5 02:15:02 kernel: [59672.860909] [] (netlink_rcv_skb) from [] (netlink_unicast+0x154/0x204)
Nov 5 02:15:02 kernel: [59672.869167] [] (netlink_unicast) from [] (netlink_sendmsg+0x2cc/0x354)
Nov 5 02:15:02 kernel: [59672.877427] [] (netlink_sendmsg) from [] (sock_sendmsg+0x14/0x24)
Nov 5 02:15:02 kernel: [59672.885251] [] (sock_sendmsg) from [] (___sys_sendmsg+0x1cc/0x1d4)
Nov 5 02:15:02 kernel: [59672.893162] [] (___sys_sendmsg) from [] (__sys_sendmsg+0x3c/0x68)
Nov 5 02:15:02 kernel: [59672.900986] [] (__sys_sendmsg) from [] (ret_fast_syscall+0x0/0x3c)
Nov 5 02:15:02 kernel: [59672.909165] ---[ end trace 88b0470bc2ba5e06 ]---
I've had more of the above errors again today at 8am in the logs, i can post on request, also I am getting some other errors. I have sent a feedback report too. Only thing different I have done is not use ipv6, if related as keep seeing ipv6 in the errors.
STARRAIN_ROG
Hi TrebleTA,
I'll report it to our tech team to check the feedback.
STARRAIN_ROG
Hi TrebleTA,
After consulted our tech team, the warning message you mentioned is qos related system notice. Our tech team have check other logs in feedback, and there is no system and hardware error, so please don't worry about the warning message.
However, our tech team found there is warning about vpn. The warning below means your vpn settings on client and server are different, and it may affect data transfer. Please check if the vpn settings are correct.
Nov 5 04:36:36 vpnclient5[16818]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1633', remote='link-mtu 1634'
Nov 5 04:36:36 vpnclient5[16818]: WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
