Results 1 to 2 of 2
    New ROGer Array Firelord01 PC Specs
    Firelord01 PC Specs
    MotherboardASUS Prime B360M-A
    ProcessorIntel Core i5 9400F
    Memory (part number)G.Skill Aegis CL16 DDR4 2x8Gb
    Graphics Card #1ROG Strix RX580
    MonitorAOC 2790G5
    Storage #1Kingston SA2000M8500G
    Storage #2Seagate Barracuda ST2000DM008
    CPU CoolerStock
    CaseDeepCool D-Shield V2
    Power SupplyAZZA PSAZ 550W 80+Bronze
    Keyboard Trust GXT 285
    Mouse Razer DeathAdder V2
    Headset Razer Kraken X
    OS Windows 10
    Nov 2021
    1
    Exclamation ROG Strix RX580 instantly getting max temps with any load
    Whenever I play any kind of GPU intensive game, the GPU always instantly shows temp readings go up to the max available 85-87 degrees Celsius. I know it shouldn't go up like so instantly but slowly over time, so is there any fix for that on the consumer level that I can do or do I just get it to the place I purchased it and ask for a replacement, bcs it's a faulty GPU? (The GPU works fine, but bcs of the temp readings it can't really work properly and the fans are going at max RPMs constantly, when in use)
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    360
    8,235
    If you are concerned that the gpu is overheating there may be an issue with the thermal paste or the cooler is not supplying sufficient even pressure. You purchased it recently? Then yes you could exchange it. If you no longer have a warranty you could remove the cooler and see if the paste has gotten dry or any screws are loose.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
Tags for this Thread
