Results 21 to 30 of 37
02-27-2022 11:25 PM #21
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 6
I got a new Z690-E the other day and memory wouldn't work in A1 or A2, only B1 and B2. Tried both a Corsair pair and Kingston. I set up a replacement with Amazon and got a new one today and all 4 slots are working. I have Corsair 5200 in slots A1 and B1 and Kingston 5200 in A2 and B2 and the machine posts. Running memtest now. When I booted they were running at 4000MHZ. I turned on XMP 1 and now it is at 5200MHZ.
02-28-2022 12:54 PM #22
Braegnok PC Specs Motherboard Asus Crosshair X670E Gene Processor AMD Ryzen 9 7950X Memory (part number) CMT32GX5M2B6000Z30K Graphics Card #1 EVGA RTX 3090 Ti FTW3 Ultra Monitor Alienware AW3423DW Storage #1 Samsung 990 Pro CPU Cooler Optimus AM5 Foundation Case Asus Prime AP201 Power Supply SeaSonic Prime TX-1600 Keyboard Das Keyboard 4 Ultimate Mouse G502 Lightspeed Headset SteelSeries Arctis Pro OS Windows 11 Pro
- Join Date
- Nov 2019
- Reputation
- 40
- Posts
- 439
If you need 64GB system memory, I recommend going with 2x32GB vs 4x16GB.
Check your motherboard QVL for 2x32GB compatibility, the Dell 4800MHz 2x32GB sticks are listed in my QVL: https://www.dell.com/en-us/work/shop...=04&l=en&s=bsd
The Dell 2x32GB sticks will run fine in XMP 4800, or manual settings up to 6000MHz on my board.
Attachment 92314
Also the Corsair 2x32GB 5200MHz kit works on my board in XMP 5200, or manual settings up to 5600MHz: https://www.corsair.com/us/en/Catego...coupon=Content
Attachment 92315
My advice would be the Dell kit, and run in enhanced mode @ 4800MHz CL32, CR1, 1.10V and you will be fine.
You need a CPU with a vary strong IMC to run 2x32GB @ 6000MHz 1.43V,.. and performance is not much better than 4800MHz CL32, CR1, 1.10V.
Good luckLast edited by Braegnok; 03-01-2022 at 12:38 AM.
02-28-2022 01:03 PM #23
- Join Date
- Nov 2019
- Reputation
- 40
- Posts
- 439
Check your motherboard GVL for 2x32GB compatibility, the Dell 4800MHz 2x32GB sticks are listed in my GVL: https://www.dell.com/en-us/work/shop...=04&l=en&s=bsd
Attachment 92314
Attachment 92315
My advice would be the Dell 2x32GB modules, and run in enhanced mode @ 4800MHz CL32, CR1, 1.10V and you will be fine.
You need a CPU with a vary strong IMC to run 2x32GB above 5200MHz CL40, CR2 up to 6000MHz,.. and performance is not much better than 4800MHz CL32, CR1, 1.10V.
Good luck, YMMV depending on your CPU IMC.Last edited by Braegnok; 02-28-2022 at 01:08 PM.
02-28-2022 02:03 PM #24
- Join Date
- Nov 2021
- Reputation
- 33
- Posts
- 108
Exactly the same happened in my case. A1 and A2 would not work, only B1 and B2. Vendor changed the board, and then it worked. I have seen many similar reports about Z690 STRIX boards. It's like a lottery. I think we have to assume that there is a hardware /design issue.
02-28-2022 04:54 PM #25
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 6
If that is your system you are far ahead of me. I can't spend that kind of money anymore. Wife would kill me. I have a 12700K with a Samsung 980 pro and no discrete graphics yet. I'm looking for a 3080 but I'm just not paying those prices so until they come down to more reasonable prices I'll do without. I'm not gaming so the need isn't there.
Any reason why I shouldn't go with 4x16s? I can't drop over a grand on memory. These 2 kits cost me about $600 and honestly, I'm not sure I want to tempt fate and mess around with the MB again. Originally I was only gonna 2 32GB but I just don't feel like returning the memory. Already had to send the bad board back.
03-01-2022 12:43 PM #26
- Join Date
- Nov 2019
- Reputation
- 40
- Posts
- 439
Best reason why not to go with 4x16GB DDR5,.. would be currently there is no solid BIOS/Microcode for running 4x16GB DDR5 on your motherboard past 4000MHz.
Perhaps down the road when DDR5 4x16GB kits are more mainstream, testing will be done and new BIOS/Microcode will be released.
As of today I have only seen one DDR5 4x16GB kit for sale : https://www.newegg.com/zvvn-64gb-288...quicklink=true
,.. and that kit today would most likely run at 4000MHz on your motherboard.
Current DDR5 Memory Support: "If the motherboard has two slots total, than the maximum support is DDR5-4800 in any configuration. If the motherboard has four memory slots total, than the maximum support is DDR5-4400 when two slots are filled with any memory.
If all four memory slots are filled, single rank memory will support up to DDR5-4000.
If all four memory slots are filled, dual-rank memory will support up to DDR5-3600."
DDR5 Memory Varies with Number of Modules: https://www.anandtech.com/show/16959...november-4th/4Last edited by Braegnok; 03-01-2022 at 12:58 PM.
03-01-2022 02:39 PM #27
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 6
Ok. Still not sure I want to mess with anything. Also, I am running 2 different 2X16GB kits. One is the Corsair and one is the Kingston. The Kingston is on the board compatibility list. Both are 5200MHz and look like they have the same timing. I ordered the Kingston because at first I thought the Corsair kit was bad. In the end, it was the MB. I decided to keep both and as I said before I don't really want to tempt fate with messing with memory again. I did manually set the memory to 5200MHz in the bios but didn't change anything else and it passed the memtest and so far hasn't given me any bluescreens or any other issues. I did look at the 2x32GB kit you mentioned but I don't see it for sale anywhere
03-02-2022 02:36 AM #28
- Join Date
- Nov 2019
- Reputation
- 40
- Posts
- 439
The Dell Hynix modules are sold per module, direct from Dell: https://www.dell.com/en-us/work/shop...=04&l=en&s=bsd
The Corsair Micron modules are sold in a kit of two modules, direct from Corsair: https://www.corsair.com/us/en/Catego...coupon=Content
03-02-2022 02:45 AM #29
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 6
03-02-2022 11:02 AM #30
- Join Date
- Nov 2019
- Reputation
- 40
- Posts
- 439
Page 8 of your motherboard memory QVL shows all three 8GB, 16GB, and 32GB Dell 4800 modules, they are listed as Venders: SK Hynix.
Attachment 92331
Attachment 92332
Attachment 92333Last edited by Braegnok; 03-02-2022 at 11:20 AM.
