Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Guru: Yellow Belt Array
    Dec 2018
    15
    129
    Angry Armoury crate error 504 [serious problem] i will cry
    Hello Asus support i have issue showing this when i want to install armory crate on motherboard ROG MAXIMUS X FORMULA
    can someone help me because i need it to modify my asus theta 7.1 headset surround sound
    Note : I have connection 1gig also firewall is off not block anything no vpn nothing fresh windows having this issue
    also uninstall tool only open for 1 min and close automatically without giving error or something
    also i checked if crate installed before there is no single armory crate file installed on my windows i just want to install armory crate what is this ?
    thanks
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    360
    8,194
    You could try reading Jimbo's thread. This is not a recommended ASUS procedure but if you have already tried the uninstall tool then it might help.
    https://rog.asus.com/forum/showthrea...e-installation
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array Jimbo93 PC Specs
    Jimbo93 PC Specs
    Laptop (Model)ABS Master Gaming PC
    MotherboardASUS Prime B560M-A AC
    ProcessorINTEL i5 10400F
    Memory (part number)G.SKILL F4-3200C16D-16GVKB x 2
    Graphics Card #1ASUS DUAL-RTX3060TI-O8G-V2
    Sound CardRealTek HD
    MonitorSAMSUNG 40" LCD
    Storage #1INTEL SSD PEKNW512GB NVMe
    CPU CoolerTHERMALTAKE UX100 ARGB
    CaseTUF GAMING GT301
    Power SupplyASUS TUF GAMING BRONZE 650W
    Keyboard TUF GAMING K1
    Mouse TUF GAMING M3
    Headset/Speakers Cambridge Works PC
    OS Win 11 Home 21H2 22000.376
    Accessory #1 Windows Feature Experience Pack 1000.22000.376.0
    Oct 2021
    81
    326
    Quote Originally Posted by lLegendaary View Post
    ...also uninstall tool only open for 1 min and close automatically without giving error or something
    thanks
    If the uninstall tool doesn't give you a message about finishing and restarting computer that is not good. Once an installation fails it can be tough to fix. The other important thing to check is the drivers for the motherboard. Do you have the Asus Motherboard support cd? Have you used it to check and install the drivers?
    Dec 2018
    15
    129
    i appreciate your help but nothing solve ?
    and what's up with cd driver lol everything in asus website the issue that the armoury bugging with me for some reasons
    Dec 2018
    15
    129
    once i open Armoury Crate Uninstall Tool it close automatically after press uninstall
    also for installer after press install it show me error 504
    check your connection but my connection is fine ?
    Dec 2018
    15
    129
    this Armoury Crate Lite Logs
    https://easyupload.io/by2hyt
  7. #7
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    81
    326
    Take a look here:
    https://rog.asus.com/forum/showthrea...-problems-imho
  8. #8
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    81
    326
    Quote Originally Posted by Jimbo93 View Post
    After many struggles with AC software I have learned that drivers are critical and that the easiest way to make sure they installed right for Armoury Crate is to use the support cd and run setup and let it detect drivers and install or reinstall them.
  9. #9
    Dec 2018
    15
    129
    I fully formatted from windows 10 to windows 11 same issue.
    I did not reset windows i fully formatted my windows but still having same issue .
    I have no clue i think my motherboard not recognize by ASUS or whatever idk
    I only need armoury crate to run THETA 7.1 HEADSET with full feature .. but i think i will sell my asus product like this way i dont know what's wrong with this
    My motherboard model https://www.asus.com/uk/supportonly/...Desk_Download/
  10. #10
    Dec 2018
    15
    129
    Solved from itself?
    Somehow what the heck is going on it solved now ...
    maybe the server i try to connect to was offline for 12 hours lol kekw
    anyway appreciate
