Armoury crate error 504 [serious problem] i will cry
lLegendaary
Hello Asus support i have issue showing this when i want to install armory crate on motherboard ROG MAXIMUS X FORMULA
90581
can someone help me because i need it to modify my asus theta 7.1 headset surround sound
Note : I have connection 1gig also firewall is off not block anything no vpn nothing fresh windows having this issue
also uninstall tool only open for 1 min and close automatically without giving error or something
also i checked if crate installed before there is no single armory crate file installed on my windows i just want to install armory crate what is this ?
thanks
12 REPLIES 12
xeromist
You could try reading Jimbo's thread. This is not a recommended ASUS procedure but if you have already tried the uninstall tool then it might help.
https://rog.asus.com/forum/showthread.php?126019-Jimbo%92s-uninstall-procedure-for-a-problem-free-re...
Jimbo93
Level 12
lLegendaary wrote:
...also uninstall tool only open for 1 min and close automatically without giving error or something
thanks
If the uninstall tool doesn't give you a message about finishing and restarting computer that is not good. Once an installation fails it can be tough to fix. The other important thing to check is the drivers for the motherboard. Do you have the Asus Motherboard support cd? Have you used it to check and install the drivers?
lLegendaary
i appreciate your help but nothing solve ?
and what's up with cd driver lol everything in asus website the issue that the armoury bugging with me for some reasons
Take a look here:
https://rog.asus.com/forum/showthread.php?126457-The-automatic-prompt-to-install-Armoury-Crate-is-on...
Jimbo93 wrote:
Take a look here:
After many struggles with AC software I have learned that drivers are critical and that the easiest way to make sure they installed right for Armoury Crate is to use the support cd and run setup and let it detect drivers and install or reinstall them.
I fully formatted from windows 10 to windows 11 same issue.
I did not reset windows i fully formatted my windows but still having same issue .
90586
I have no clue i think my motherboard not recognize by ASUS or whatever idk
I only need armoury crate to run THETA 7.1 HEADSET with full feature .. but i think i will sell my asus product like this way i dont know what's wrong with this
My motherboard model https://www.asus.com/uk/supportonly/ROG%20MAXIMUS%20X%20FORMULA/HelpDesk_Download/
lLegendaary
once i open Armoury Crate Uninstall Tool it close automatically after press uninstall
also for installer after press install it show me error 504
check your connection but my connection is fine ?
lLegendaary
this Armoury Crate Lite Logs
https://easyupload.io/by2hyt
lLegendaary
Solved from itself?
Somehow what the heck is going on it solved now ...
maybe the server i try to connect to was offline for 12 hours lol kekw
anyway appreciate
