Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    New ROGer Array
    Oct 2021
    15
    Thumbs up Armory Crate, i need help.
    Your software is a load of crap fix it. what nis the point of selling hardware that you cant controll with the software look at the posts of people having problems with Armory Crate.
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    Motherboardz490 XII Apex 2nd x299 VI Apex 3rd x99 sabertooth
    Processori9-10900k w/Foundation & i9-9940x w/SigV2 & 5930k w/ek-Magnitude
    Memory (part number)Trident-Z 3600c16 2x8 2nd Trident-Z 3600C16 4x8 3rd 3200c14 4x8
    Graphics Card #1Titan Xp & 1080ti FTW3 both water cooled & evga 980ti gaming on air
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads & 2 Test Benchs
    Power SupplyEVGA 1000P2 & 1200P2 & 850p2
    Keyboard 3x Logitech G710+
    Mouse 3x Red dragon Perdition
    OS Linux-Cinnimon 20.2 & Win-7-10-11 pro
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 Mayhems clear all
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    30
    422
    Bios level installing malware
    Just ai suite.. by another weird name.
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z - 3600MHz 15-15-15-30-1T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Keyboard ROG Falchion NX
    Mouse ROG Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,803
    Hey guys,
    Please tell us a little more about the problem,
    For instance, what all you're trying to control, what windows version and is it fully updated. Are you on the latest bios and all drivers updated. And does your motherboard meet the Armoury Crate requirements.
    Things like this can help diagnose the problem. I'm on a z270 motherboard and know there are certain things I can't do.
    https://www.asus.com/us/support/FAQ/1042459/
    New ROGer Array
    Oct 2021
    15
    Quote Originally Posted by Nate152 View Post
    Hey guys,
    Got a Tuf K3 keyboard that i cant change the rgb lighting on since the last armory crate update it worked on 3.1 but wont work on version 4.2 plus the Tuf gaming Hal wont update its stuck on 1.01.48. plus when i select the device from devices i get the message "please wait for asus framework service to respond
    and the device page will be reloaded automatically.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse ROG Spatha X
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,803
    Thank you,
    So it seems your stuck updating the Hal for your keyboard is the issue. Since I didn't have any trouble updating the Hal in my devices, I'll have to research this.
    Hang tight, I'll see what I can find.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse ROG Spatha X
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,803
    Try disconnecting your keyboard and reconnecting it, restart your pc too. I see your TUF Gaming K3 is on the supported product list so maybe it's something simple that will get it to update.
    Just to confirm you're up to date with Armoury Crate.
    Click the picture to make it bigger.
  7. #7
    New ROGer Array
    Oct 2021
    15
    yes up todate with armory crate
  8. #8
    New ROGer Array
    Oct 2021
    15
    when I first load Armory crate i get this Click image for larger version.
    then when i click check for updates i get this Click image for larger version.
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse ROG Spatha X
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,803
    Thank you,
    All you should need to do is click update and let it do its thing, I'm a bit puzzled myself.
    What I will say though is...
    Try it again, if you still get the "framework service not responding" we'll focus on this.
  10. #10
    New ROGer Array
    Oct 2021
    15
    Thank you,
    tried that it just reverts to needing the update just checked in device manager and the driver has installed as a mouse instead of a keboard, so going to uninstall and remove all reg and services and try and install again, i dont suppose you just have a link to the driver inf file.
