Results 1 to 4 of 4
    New ROGer Array
    Nov 2021
    2
    AIO Cooler on ASUS MOBO [Help]
    I have a Cooler Master ML240L RGB connected to an ASUS ROG Strix B450-F Gaming II.
    The Pump is connected to AIO_PUMP socket, both radiator fans (using a splitter) are connected to CPU_FAN plug socket.
    When I turn on the PC, the liquid cooler fans start up at full speed and then spin normally.The PC does not give any type of error, everything works correctly in Windows and in games, the temperatures are also normal. Everything works perfect, except for that little detail when the PC starts up.
    This is normal? Or is there a way to solve this?
    I hope you can help me.
    Thanks!
    ROG Enthusiast Array AfterShock PC Specs
    AfterShock PC Specs
    MotherboardAsus Crosshair VIII Hero
    ProcessorAMD Ryzen 3800XT
    Memory (part number)F4-3200C14-16GFX
    Graphics Card #1Evga RTX 2080 Super
    Sound CardOnboard
    MonitorAsus VE278Q
    Storage #1Corsair MP500 M.2
    CPU CoolerNZXT Kraken X3
    Casecorsair crystal 570x
    Power SupplyCORSAIR RMx Series 850W
    Keyboard Corsair Strafe mk2
    Mouse Logitech G903
    Headset Raze Nari Ultimate
    Mouse Pad Logitech PowerPlay
    OS Windows 10 Pro
    Network RouterBuffalo WZR-1750DHP
    Oct 2015
    55
    Quote Originally Posted by chnxx View Post
    Thanks!
    It's normal at least for every asus motherboard I've ever owned.
    ROG Guru: Green Belt Array
    Feb 2019
    129
    694
    Its normal for them to ramp up to full speed momentarily. Know as a boost start to make sure they arent below stall.
    New ROGer Array
    Nov 2021
    2
    So, I have nothing to worry about?
    Oh great Now I'm going be able to sleep.
    Thanks!
