RX6800M gives similar specs as RX6700XT? Really?! Insane score!
MyRyzenWorld
Level 11
HWINFO Specs:
https://i.imgur.com/ZSRWJwm.png
Score:
http://3dmark.com/fs/26667254
What ya saying guys?
Just to be clear guys, this is ASUS G513QY #AMD Advantage Edition laptop.... temps are high coz I was just having short #COD #Vanguard session and you know temps are high on these laptops, so...no cluch. But wattage, performance... surprising for a mobile thing!
6 REPLIES 6
Nate152
Hi MyRyzenWorld,
Jeeeez,
Not only did you beat the other gaming laptops, you blew them away.
I do see the cpu temp hit 96c, might need a little more fan.
That's amazing and quite impressive.
Nate152 wrote:
Hi MyRyzenWorld,
Jeeeez,
Actually Fans set 100% already and CPU set to 75W limit APU in Crate....
Cant do much on the temps side, the laptop arrived out of the box pretty hot, I mean GPU was peaking hotspot at 102-103c, I actually repasted the thing myself, and ended up take it to professional laptop LAB nearby and paid them to repaste it with Gelid GC Extreme (both CPU and GPU), which allows now bring the max GPU hotspot down to somewhere across 96-98c zone. Per AMD support RX6800M by design can handle 110c without damaing/life short itself. I did see other G513QY owners that also hitting 102c GPU hotspot, but not everyone want go and repaste, as it can void warranty, in my case, since I live outside US and I bought this laptop Sept 24 in US, I anyways dont have warranty, so I could do stuff without losing warranty which I anyways dont have (US only warranty).
Now for CPU? Same story pretty much, out of the box from ASUS it was peaking around 95c so... and per AMD support Ryzen 5900HX can handle without damage itself 105c, so its fine.
But I agree 100% cooler always better, I wanna try and get this crazy IEST GT500 cooling pad, its a monster ! ! but probably gonna have buy it off Amazon, since no one selling it here in my country.
Created HWINFO recordings during Heaven and TimeSpy:
Here TimeSpy recording of HWINFO during whole TimeSpy run, score should be around 11500 approx but lower since recording was running I guess... :
https://mega.nz/file/Ts8WBBAC#z5fkNl6PF6UeBibKnsEF9Gpdh_jM3nuEj2kOXuUbbOw
During Heaven:
https://mega.nz/file/nl013YTI#XHwWCQUC7neGXqhxfDJXB9k1OwrExu_mOR45K-foSPY
Nate152
Do you have the ROG Strix G15 Advantage Edition?
How about you record us a video of your favorite game, and show performance with an FPS counter and other things like gpu temp and cpu temp.
1. G513QY Advantage Edition, Revision M5, you asked about temps? it is custom pasted (original LM pasting was hooking my GPU hotspot to 101-102c, I took the laptop to computer LAB, bought a repasting service, they repasted both CPU and GPU, now GPU mainly peaks at 95-98c, which is much better than 102c....) per AMD support RX6800M designed safely operate up to 110c and CPU peaking in gaming around 05-97c which is per AMD support also fine as AMD said, this CPU designed to operate safely up to 105c). Repasting done using Gelid GC Extreme, which is one of the industry best thermal pastes available.
2. Now, you wanna see some action? sure - I am in a closed beta for WW3 game:
https://www.youtube.com/watch?v=F8-ERlC5Mh4&t=4s
Tomorrow first closed beta access, I will be streaming: https://www.twitch.tv/xoidf
When exactly? not sure yet, I will post here once I begin 🙂
DISCLAIMER: Fact I repasted my unit shortly after it arrived to me, does not mean you should. Its just me and my decision.
Nate152
I'd like to see a video of you playing on your G513QY Advantage Edition, with performance and temps here in your thread.
I'm showing performance and temps with Gpu Tweak in the upper right. I'm not concerned about mine, I'd like to see a game on yours. Would you have any on youtube to share?
