Results 1 to 4 of 4
    New ROGer Array
    Apr 2021
    4
    Hidden AVX-512 offset
    When using AVX-512 feature e-cores disabled, there seems to be negative ratio offset of -1 during AVX-512 loads. Please give us options to disable this.
    ASUS TUF Z690 D4
    Beta BIOS 8003
    Super Moderator Array
    Jul 2011
    103
    790
    ok will add!
    New ROGer Array
    Nov 2021
    33
    108
    Quote Originally Posted by Hermanos94 View Post
    ASUS TUF Z690 D4
    Beta BIOS 8003
    Excuse the noob question: how do you disable in BIOS the e-cores?
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    199
    2,556
    ASUS TUF Z690 D4
    Beta BIOS 8003
    Hello,
    Are you using Prime?
    Prime95 AVX workloads have a 51X ratio cap irrespective of user-applied settings.
