Results 1 to 10 of 12
11-27-2021 06:09 PM #1
JeffroMan PC Specs Motherboard Z690 Maximus Hero Processor i9-12900KF- Alder Lake Memory (part number) Corsair DDR5 CMT32GX5M2B5200C38 Graphics Card #1 Asus RTX 2060 OC Strix Sound Card Integrated Audio Monitor Asus ROG XG349C Storage #1 Samsung 1TB EVO 860 SSD Storage #2 Samsung 1TB 980 Pro NVME 4.0 SSD CPU Cooler Corsair iCue H115i Elite Capellix Case Corsair Carbide Series Air540 Power Supply EVGA 1200 P2 Platinum Keyboard ROG Strix Flare Mouse ROG Chakram Core Headset Corsair Virtuoso RGB Wireless XT T-Pain Edition Mouse Pad ROG gaming mat OS Windows 11 Home 64 bit
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 18
Unusually high chipset temperature?
I could not find this information elsewhere. I have a Z690 Hero Maximus Mobo. With default settings loaded in BIOS, UEFI reports that the chipset temperature is anywhere from 46 - 52 degrees celsius. That is within the UEFI BIOS setup monitoring screen. Can anyone else let me know what they're seeing for this temperature within BIOS with this motherboard?
11-29-2021 07:43 AM #2
Hello,
50C is fine and well within operating limits. Mileage will vary depending on ambients
12-01-2021 09:05 PM #3
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 18
Thanks, good to know. Ambient temperature was around 70 degrees Fahrenheit.
12-02-2021 06:49 AM #4
- Join Date
- Feb 2019
- Reputation
- 129
- Posts
- 709
Its always seemed high to me but its been the same range across multiple motherboards.
12-07-2021 07:27 PM #5
Adrian1983 PC Specs Motherboard Asus Maximus XI Hero Processor I7 9700K @ 5.1 Memory (part number) CMK32GX4M2D3000C16 @ 3600 32gb Graphics Card #1 Zotac RTX 3080 Trinity Sound Card Hdmi Monitor Sony 55" Tv Storage #1 Samsung 970 Evo Plus X2 Storage #2 Samsung 840 Pro CPU Cooler Corsair H150i Pro Case Fractal Design Define S2 Vision RGB Power Supply Seasonic focus gold 850w Keyboard Logitech G915 Mouse Logitech G703 Headset Logitech G935 OS Windows 10 x64
- Join Date
- Jun 2019
- Reputation
- 34
- Posts
- 144
You think that's bad here's my Z690 Gaming APCH Temp just reached 65c just loading WIndows up at boot, It's 0c here in the UK and the ambient is cool.
If I start gaming it reaches 73c I am not happy with this and may send it back for a different board, There's a reason why board makers started to add fans to the chipset on PCIE 4.0 AMD boards and it's this reason, What's the point in doing everything humanely possible to cool a CPU when onboard chips run this hot.
12-18-2021 08:06 AM #6
- Join Date
- Dec 2021
- Reputation
- 14
- Posts
- 13
It's unclear, but your situation may indicate a heat-related issue. If you haven't been running any high-intensity programs, it could be something as simple as bad ventilation in the case. But if you have been playing VR games or using intensive graphics applications, then I recommend contacting customer service for a diagnostic and repair process to help identify the problem before it becomes serious or permanent damage occurs. They're there to help.
12-18-2021 08:43 AM #7
Hello, it might be worth asking what's connected to the system. Multiple storage devices will put load through the PCH. Of course, it's of no consequence, as the chipset is designed to operate well within those limits.
01-05-2022 04:09 PM #8
wladxq PC Specs Motherboard ROG STRIX Z690-G GAMING WIFI Processor Intel Core i7-12700KF Memory (part number) F5-5200U4040A16GA2-RS5W Graphics Card #1 NVIDIA GeForce RTX 3060
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 2
01-08-2022 06:27 PM #9
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 2
Hello,
Same problem here as well.
ASUS support was useless. "If you think something is wrong, return it"...instead of actually helping me with some problem solving or giving some answers.
- The chipset 70C+ while the rest of the system is cool. It's not an airflow-issue. I do however have 2x nvme installed, so it might be that putting some load on the PCH.
- The GPU is located above the chipset. GPU is 40 degrees, so it should actually be chilling the chipset which is 70+.
- Managed to get it down a few degrees by tweaking the BIOS.
My best guess atm:
- I think it might be poor thermal pads - anyone poppet the heatsink off and had a look?
- Additional BIOS-related load-reduction of the PCH as a temporary workaround.
01-14-2022 02:48 AM #10
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 2
Same here
Z690 G Gaminig-wifi , arounf 65-70 deg C on Chipset, while CPU is ~35, and "motherboard" is 43 .... and I think I have a good airflow ...
I suspect the problem is because of the graphic card which doesn't let the air to flow above the chipset radiator ...
Also .. when I force to start (or higher RPM) for GPU fans, then the chipset temp decreases a little ... I'm thinking to put an additional cooler somewhere... on the bottom , just to blow air to the chipset radiator ...
