Results 1 to 4 of 4
    ROG Enthusiast Array
    Dec 2016
    47
    Asus Maximus Extreme Z690 - USB Device Error Failed
    I am having an issue with the following and I can't find the driver responsible to resolve this issue.
    I need help with this one, can't figure it out.
    System Details:
    Windows 11 Pro - 64bit
    Motherboard: Asus Maximus Extreme Z690
    Processor: Intel 12900k
    GPU: Asus Strix OC 3090
    Memory: 32GB Corsair Dominator 5200Mhz
    Issue:
    Failed Driver for USB Unknown Device
    Device Type: Universal Serial Bus controllers
    Manufacturer: (Standard USB Host Controller)
    Device Status:
    Windows has stopped this device because it has reported problems. (Code 43)
    A request for the USB device descriptor failed.
    Device Instance Path:
    USB\VID_0000&PID_0002\6&2AB426AA&0&4
    Driver Problem Description:
    Device USB\VID_0000&PID_0002\6&2ab426aa&0&4 was configured.
    Events:
    Driver Name: usb.inf
    Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
    Driver Date: 06/21/2006
    Driver Version: 10.0.22000.1
    Driver Provider: Microsoft
    Driver Section: BADDEVICE.Dev.NT
    Driver Rank: 0xFF0000
    Matching Device Id: USB\DEVICE_DESCRIPTOR_FAILURE
    Outranked Drivers: usb.inf:USB\DEVICE_DESCRIPTOR_FAILURE:00FF2000
    Device Updated: false
    Parent Device: USB\VID_05E3&PID_0610\5&2cf64626&0&10
    ROG Enthusiast Array theroc44 PC Specs
    theroc44 PC Specs
    MotherboardZ690 Extreme
    Processor12900k 5.1GHZ
    Memory (part number)Corsair Dominator 32gigs 6200 CAS 36 DDR%
    Graphics Card #1EVGA 3090 FTW Ultra
    Sound CardCreative Soundblaster AE-9
    MonitorAsus Rog Swift PG32UQX
    Storage #1Samsung 980pro 2tb
    Storage #2WD SN850 2tb
    CPU CoolerMSI Meg Coreliquid 280r
    CaseCoolermaster C700p Black Edition
    Power SupplyASUS Rog Thor 1200 Certified 1200W Fully-Modular RGB
    Keyboard Logictech G915
    Mouse Logictech G502
    Headset Logictech G935
    Mouse Pad Logictech Lightning Pad
    Headset/Speakers Logictech Z906
    OS Windows 11 Professional
    theroc44's Avatar
    May 2015
    11
    69
    Try the windows update optional list see if anything there is what you need. When I upgraded to the 6950x from 5930k I had a USB error too. It was fixed with that.
    PS- its called intel driver support assistant, not saying it will fix it but... ya never know
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    199
    2,558
    Aside from attempting to use the assistant, best to plug in each of one's peripherals/USB Devices until the error is visible within Device Manager to isolate the device.
    New ROGer Array
    Jan 2019
    1
    might help
    Quote Originally Posted by theonecsm View Post
    System Details:
    Issue:
    Device Status:
    Events:
    had the same problem except it was causing bluetooth not to load. try this shut down your computer switch off power supply unplug it then while unplugged press and hold start button for about 10 seconds to get rid off excess current then reconnect everything then start computer it worked for me.
