Results 1 to 5 of 5
    New ROGer Array Jimbo93 PC Specs
    Jimbo93 PC Specs
    Laptop (Model)ABS Master Gaming PC
    MotherboardASUS Prime B560M-A AC
    ProcessorINTEL i5 10400F
    Memory (part number)G.SKILL F4-3200C16D-16GVKB x 2
    Graphics Card #1ASUS DUAL-RTX3060TI-O8G-V2
    Sound CardRealTek HD
    MonitorSAMSUNG 40" LCD
    Storage #1INTEL 660p NVMe SSD PEKNW512GB
    CPU CoolerTHERMALTAKE UX100 ARGB
    CaseTUF GAMING GT301
    Power SupplyASUS TUF GAMING BRONZE 650W
    Keyboard TUF GAMING K1
    Mouse TUF GAMING M3
    Headset/Speakers Cambridge Works PC
    OS Win 11 Home 21H2 22000.438
    Accessory #1 Windows Feature Experience Pack 1000.22000.438.0
    Oct 2021
    80
    353
    I have this pre-built system with some kind of aura extension card
    I have this pre-built system with some kind of extension card that must control fan lights, both cpu and front case fans. These fan lights have a rotating rainbow like color pattern. I assume there is some way to change the light pattern but there is no device in armoury crate to change. I guess I need to crack it open or call the builder.
    There is an AURA LED controller I see in device manager, that must be it, or could that be a built-in device on the motherboard? I am thinking some other software can change the light pattern.
    Hardware id is USB\VID_0B05&PID_19AF&MI_00.
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    80
    353
    The cpu fan is a thermaltake. Maybe I need Thermaltake software for that. Not sure about the brand of the case fans
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    80
    353
    Making some progress.
    My case, the TUF Gaming GT301, came with that LED controller extension card. I can change the case fan light pattern manually with a button next to the power on/off. And I can depress the button for 5 seconds and enable motherboard mode which allows Armoury Crate to control them through the Addressable LED connections. Still need to get the Thermaltake fan to work with AC. Should be possible I think.
    ROG Enthusiast Array GObonzo PC Specs
    GObonzo PC Specs
    Laptop (Model)Lenovo IdeaPad G780
    MotherboardROG Strix Z590-E Gaming
    Processori7-11700K @5.2GHz
    Memory (part number)F4-3200C14D-32GTZSK-G.SKILL
    Graphics Card #1ASUS TUF RTX 3080 Ti
    MonitorAlienware AW3420DW (34" 3440x1440p)
    Storage #1M.2 NVMe: 2x MP510 512GB \ 2.5" SATA III: 1x 4TB, 1x 1TB
    Storage #2external HDs: 16TB
    CPU CoolerASUS Ryujin 360
    CaseFractal Design Vector RS (5x be quiet! Silent Wings 3 140mm High-Speed PWM)
    Power SupplySuper Flower Leadex III 850w Gold
    Keyboard Corsair K70 LUX RGB — CHERRY® MX RGB Brown
    Mouse Logitech G600, Corsair Vengeance M95
    Headset Soundcore Q20 Life
    Mouse Pad 24" x 12" extended
    Headset/Speakers Klipsch ProMedia 2.1
    OS Windows 10 x64 Pro
    Network RouterWAVLINK AC1200
    Accessory #1 Microsoft XBOX One S Gamepad
    Accessory #2 ASUS USB 2.0 DVD-RW (SDRW-08D2S-U)
    Accessory #3 LG CX 55" TV
    GObonzo's Avatar
    Apr 2019
    58
    Quote Originally Posted by Jimbo93 View Post
    this fan would need to have an LED cable attached to a motherboard RGB header for software control.
    if it is a Thermaltake proprietary device then it will have it's own built-in controller in the form of an attached controller with buttons.
    if this is the case it can possibly also have a separate cable leading out from the controller for motherboard control.
    it's also possible that this is not a RGB fan and only has auto patterns or a solid color.
    check the fan model and see what it's specs are.
    ASUS ROG Strix Z590-E Gaming | i7-11700K \ ASUS ROG Ryujin 360 | G.Skill TridentZ 3466 CL14 32GB | ASUS TUF RTX 3080 Ti | M2: 960GB \ SSDs: 5TB \ HDs: 16TB | Super Flower Leadex III 850w | Fractal Design Vector RS Blackout \ 5x be quiet! Silent Wings 3 140mm High-Speed PWM | Logitech G600 | Corsair K70 LUX RGB | Xbox One S Gamepad | Klipsch ProMedia 2.1 | Anker Soundcore Life Q20 | 34" Alienware AW3420DW \ 55" LG CX OLED | Windows 10 Pro x64
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    80
    353
    Quote Originally Posted by GObonzo View Post
    it is asus argb compatible, just wasnt hooked up to header. Working now. Thanks for reply.
