How to control the CPU Fan
Angween
Hello, I have G51VX, undervolting my CPU and i like it, the only problem I have now is the CPU fan always get turn off if the CPU get bellow 50 C or something, its good actually but it ignoring my GPU heat that is still above 80 C. And now i often find my GPU temperatures get more than 100 C when playing a game after a few minutes.
I wonder if there is any tool that could control the cpu fan to keep it always ON or change the settings when it should be turned off.
Hope my Engrish not confusing anyone, and thanks.
Retired
Not applicable
thats a tough one, since undervolting your system is not its factory settings, it cant really give advice on how to optimize your system the way its currently set up. why did you undervolt it? better battery life or temps?
Angween
better battery live. but now i uninstall-ed undervolting software and back to default setting. still can not clear my problem: gpu heat, it still reach 105 degree in 5-10 minutes playing Dragon age: origins or any 'heavy' game.
