Results 1 to 10 of 10
    ROG Enthusiast Array
    Jul 2019
    41
    Z690 Extreme GPU Slot won't lock
    My 156x GPU slot, the with the new button to release the lock doesn't lock when I put my GPU in. No matter how much pressure the clip won't lock and the card can slid out all on it's own.
    Is there anyway to fix this on my own or is this already an RMA?
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71 Win 11 Pro 21H2
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 21H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    284
    already an RMA?
    Reads as though that One Tap, PCIe Slot Q-Release technology mechanism might not be working well on some Z690 motherboards as intended.
    Jul 2019
    41
    No it doesn't appear to be working that great. Likely will be sending this in for an RMA if not a full refund and grabbing a new different board
    Jul 2019
    41
    Ended up returning the board. Have an Apex coming instead, hopefully no issues with that one
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus MZ690E Bios 1505
    Processori9 12900KS
    Memory (part number)GSkill F5-6400J3239G16GX2-TZ5RK
    Graphics Card #1Asus 3090 Ti Tuf
    Sound CardCreative SB X4
    MonitorAsus ROG XG349C
    Storage #1Samsung 980 Pro
    CPU CoolerQuantum Kinetic TBE 300 D5 with Quantum VTX 160
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus ROG Claymore 2
    Mouse Asus ROG Gladius III
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    70
    2,481
    Have the same problem with my extreme board too. Seems to work fine regardless.
    ROG Enthusiast Array captaintrips PC Specs
    MotherboardAsus Maximus Extreme Z690
    ProcessorIntel i9 12900k @ 5.4ghz
    Memory (part number)Adata XPG Lancer DDR5 - 4x16GB - 64GB - 5200mhz
    Graphics Card #1Nvidia Geforce RTX 3090 FE
    Sound CardAsus XtremeFX onboard
    MonitorLG CX 65 OLED - 4k 120hz G-sync
    Storage #1Sabrent Rocket 4TB PCIE4.0 NVMe
    Storage #2Sabrent Rocket 4TB PCIE4.0 NVMe
    CPU CoolerAsus Ryujin II 360
    CaseCoolermaster C700M
    Power SupplyEVGA Supernova G3 1000w
    Keyboard Bloody laser-switch wired / Corsair K63 wireless
    Mouse Corsair M65 PRO wired / Corsair Dark Core Pro wireless
    Headset Steelseries Artcis 9
    Mouse Pad Corsair MM800 Polaris / Corsair Lapboard
    OS Windows 11 Pro
    Network RouterPFsense mini-pc
    Oct 2018
    30
    Same issue. Using a 3090 FE. Doesn't budge or feel loose, and requires a heck of a tug to pull it out. It's screwed in and I doubt it will cause any issue. Pretty secure without it locking.
  7. #7
    Jul 2019
    41
    I was using a 3090 KPE with a Optimus block so that thing is extra heavy. So gravity alone was enough to easily pull it loose. As I said I switched to an Apex so we'll see if it has the same issues
  8. #8
    Jul 2019
    41
    I sent the unit back to Newegg for a return and they are now trying to claim I broke the PCIE lock and won't accept my return. Did no such thing and they are just scamming me out of my money. WTF am I going to send it to ASus for when it's not my fault only for ASUS to either charge me to fix it or not.
    What a nightmare. I just know if I RMA with ASUS they will pull the same stunt and make me pay for the repairs for a part that came that way.
    Never again with Newegg after this.
  9. #9
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus Z690 Apex BIOS 0811
    Processor12900K w EK Velocity 2
    Memory (part number)32 GB DDR5 - Dominator 5600 / Cl36
    Graphics Card #1Evga RTX 3080Ti FTW3 Ultra w EK Vector
    Sound CardOnboard USB Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 980 Pro 512G M.2 NVMe
    Storage #2Samsung 980 Pro 1 TB M.2 NVMe
    CPU CoolerEK Velocity 2
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W11 HP x64 - 21H1
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    49
    408
    Quote Originally Posted by OutSider420 View Post
    Asus will ship you a new Board......dont worry about it.....they're pretty good with new release HW and replacement.
    Surprised Newegg is giving you some grieg.....must not be Newegg Canada as they are pretty darn good!
  10. #10
    Jul 2019
    41
    Quote Originally Posted by rjbarker View Post
    Nope was Newegg Canada. Refused to help me in anyway. I clearly explained why I was returning it and that it was defective before I got but they still chose to just blame me and send it back all without informing me of any it. I doubt I'll ever buy from them again if this is the BS they pull. Return anything defective and they will only blame you for it.
    Problem is while I'll get a replacement board since I thought I returned the Extreme I went out and grabbed an Apex instead. So now I'm stuck with two Motherboards, once of which I'll have to take a loss on reselling it. Not to mention the cost of sending the Extreme back. So all in all it's a lose lose situation for me.
