Results 1 to 5 of 5
    ROG Junior Member Array
    Dec 2016
    2
    Strix RTX 3070 fans always on at idle
    My Strix RTX 3070 fans always stays on at idle even when the Quiet mode switch is turned on. Took me a while to troubleshoot it and it turned out to be because of G-Sync. Having G-Sync on or/and running my monitor at it's overclocked speed 144 >165hz will also cause the fans to always spin at 1000RPM, regardless of the temperature. I've tried reinstalling drivers, DDU, reinstall windows and everything but as i mentioned the issue is caused when G-Sync is on or/and running the monitor at 165hz.
    Temps are low 45c idle when fans are off. I don't need these fans to stay on when GPU sits at idle but i also want to use G-Sync at the same time. I'm aware you can do a custom fan curve in something like MSI afterburner but i want to use what i get out of the box with no additional tools requires.
    OS: Windows 11 Pro
    CPU: 12900k
    GPU: ROG Strix 3070 8GB OC V2
    Monitors: ROG PG279Q
    Any help will be appreciated.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    MotherboardROG Crosshair VIII Dark Hero
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Power SupplyCorsair HX1000
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    411
    8,435
    Are you using the drivers from the Strix support page? Sometimes the latest Nvidia drivers work well and sometimes they might have strange behaviors so it's worth trying ASUS validated ones. Otherwise, it's ok at 144hz or also stays on? It might be the higher refresh is generating *just enough* load to cause the fans to stay on.
    I'd also recommend moving this thread to the GPU section in case other users have had this issue and resolved it. ASUS does occasionally read posts here from what I understand but you'd be better off contacting ASUS support to complain of the issue and looking for solutions from the community here. I can move the thread if you like. Let me know.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Dec 2016
    2
    Quote Originally Posted by xeromist View Post
    Haven't tried the Drivers from the asus website but i'll give that a try, i always get my drivers from Nvidia, since's it's an Nvidia card and they're the one providing the software not asus. Regardless running the monitors are 144hz is fine but 165hz will cause the fans to always spin up and disables 0db mode, same goes if G-Sync is on.
    Edit: I moved this thread to the GPU section, thanks for letting me know.
    New ROGer Array
    Sep 2019
    1
    Same thing happens to me, I have a STRIX RTX 2070 super Advanced and the fans are always spinning, regardless of the refresh rate of my monitor, they spin at 60 Hz or at 165 Hz
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,685
    Quote Originally Posted by MonstrousYiROG View Post
    OS: Windows 11 Pro
    CPU: 12900k
    Can you confirm what VBIOS? Remove any third party tools such as MSI AB.
