Hi
I have a problem that AI Suite 3 reads the CPU temperature completely wrong (i think). Under full load, it says 70-80ishC.
Other applications like HWMonitor, Core temp read 10-15C more. So i'm hitting sometimes 95C which is a little bit too hot.
I am using i7-11700K with Asus Rog Strix Z590-F Gaming Wifi and using the ASUS AI (5-way optimization). It thinks my max temperature is 77C.
So basically it reads wrong CPU and therefore therefore the fan curve is not right either.
Using Windows 11 and also the case was same with Windows 10. All drivers and utilities are updated to the latest versions.
What to do?
Thank you in advance!
