Dark Hero messing with fan control
arconz
Asus Dark Hero, I have 7 Lian-Li UNI fans driven by their custom controller(s), which I normally control through the Lian-Li connect app. After the latest bios update it alters the fan speeds at random... why??? I also have a noctua fan connected to H_AMP and a pump which behave normally as before as I matched their PWM fan curve in bios. Some setting is wrong with the controllers as I do want MANUAL control from within windows. Any help much apprec.
D_BRASCO
If you are using AI Suite 3 Fan Xpert 4 maybe run fan tuning again? if not I think it can also be tuned from inside the bios, maybe that will help.
As I said these use the Lian-Li connect app. No... fan controllers can't be tuned from inside the bios.
Have you tried out L-Connect Fix ?
