Results 1 to 1 of 1
    ROG Junior Member Array
    Jun 2017
    4
    aRGB Limits on Dark Hero.
    Hello all,
    So here it is : I'm very happy about my Dark Hero MB for gaming and the rest, but about christmas I started to turn my PC in a lightshow, for the kids.
    I had 120 leds across 4 devices (3 Gen 2 on one header, 1 GEN 1 on the other).
    The specs and manual say that the motherboard can handle 500 addressable leds.
    I say fine.
    I buy a 300 Leds strip.
    I plug it on one header.... and it will only lit a total of 120 leds.
    If i put the other GEN 1 through a splitter on the same header, I have those 30 plus 90 leds on the strip. If I put only the strip, it lights up 120 on the strip.
    If i mix GEN1 and GEN2 on a header, it corrupts the lighting and i get even less leds lit.
    Back to all GEN 1 on a single header, how do I get to use more than 120 leds ?
    Why does it consider different devices a single device ? (It doesn't do that on the GEN2 devices, the three fans are considered 3 independent devices of 30 leds each).
    How do i get to use the advertised 500 led if i can't have more 120 / addressable header ?
    Thank you
Tags for this Thread
