NVME 850SN (Need heatsink) x99 extreme
ThePathOfBlood
I need a heatsink that actually fits and works, anyone with the X99 EXTREME will know that it's a really small fit area for the NVME, and getting a random heatsink is out of the question, I tried a v sabrentt rocket but that was too big and a capacitor was in the way and ram slots were to close to the NVME..
does anyone know of a good heatsink for the 850
5 REPLIES 5
Szaquak
There is small problem because small space.
I have got https://pl.aliexpress.com/item/1005001657182216.html?spm=a2g0o.productlist.0.0.6e1f5432JAah0J&algo_p...
Temp below 50
Szaquak wrote:
Temp below 50
Got one that works thanks, but will favorite that page, cheers!
Stanislav_+7 wrote:
I would advise
https://www.amazon.com/Advancing-Gene-Cooler-Heatsinks-Generation/dp/B077BPPFN8
Are you sure it will fit?
On the right on the right next to the socket there is a small capacitor that effectively does not allow to mount a lot of heat sinks even if they are 1mm wider.I bought 3 and only matched.
Sizes are on the site. You can slightly sharpen the width if anything))).
