Results 1 to 10 of 10
12-30-2021 06:46 PM #1
- Join Date
- Apr 2014
- Reputation
- 10
- Posts
- 9
crosshair VIII extreme + 5950x, strange unstability issue with D.O.C.P enabled
I have the following setup:
- ROG Crosshair VIII extreme
- Ryzen 5950x
- G.SKill ram F4-3600C16D-64GVK (2 x 32GB)
At "stock" ram speed (1333Mhz), everything works fine, the system is rock solid and I can use it for days without crashing.
When I enable D.O.C.P to get 1800Mhz, the system seems stable (I can run memtest and other stress tools for hours without error), but after 2 or 3 days of uptime, often at idle or when watching youtube videos, the system suddenly becomes unstable : I cannot launch any new task, I even cannot call the task manager, all running tasks becomes unresponsive one after another. Ultimately, all I can do is a forced shutdown/reboot.
I have no WHEA errors in my event viewer.
I tried adding some voltage to the SOC with no success (up to 1.17V). But I'm pretty sure the issue is not related to the SOC voltage because as I said, all stress tests run smoothly.
I tried to disable D.O.C.P and manually set the RAM timings and voltage (up to 1.5V instead of the 1.45V required for DOCP), but no success.
I also tried to lower the ram frequency to 1600Mhz but the issue remains.
Now I'm lost because I don't even know where my problem comes from. Motherboard ? processor ? RAM ?
Can someone help me on this ?
12-30-2021 08:39 PM #2
- Join Date
- Jan 2019
- Reputation
- 68
- Posts
- 75
If it blocks the task manager, it is most probably the graphics card or the storage, anything particular to note on those ? In particular, if you are using an M.2 storage device, did you remove the film from the thermal pads under the m.2 heatsink on the board ? If you didn't, that may be your storage unit overheating and causing that issue.
Also, did you change the default motherboard BCLK by any chance ? Did you check the temperatures of the storage/graphics card hardware with a tool like HwINFO ?
In any case, if it is one of those, you should find a related critical error event in the Event Viewer under the System or Application logs around the time it happened. Did you check ?Last edited by Kelutrel; 12-30-2021 at 08:55 PM.
12-30-2021 09:57 PM #3
Ecmslee PC Specs Motherboard Asus ROG Crosshair VIII Dark Hero Processor AMD Ryzen 9 5900X Memory (part number) G.Skill Trident Z Neo 32 GB F4-3600C16Q-32GTZN Graphics Card #1 EVGA GeForce RTX 3080 10 GB FTW3 ULTRA GAMING Sound Card JDS Labs Element II Monitor PG348Q, PG32UQ Storage #1 Samsung 980 Pro 2 TB Storage #2 Western Digital Black 6 TB 3.5" CPU Cooler Corsair H115i RGB PLATINUM Case Phanteks Eclipse P500A Power Supply SeaSonic PRIME TX 1000W
- Join Date
- May 2021
- Reputation
- 33
- Posts
- 36
Have you updated the UEFI on your motherboard? The latest version is 0504 as of the time of this post.
12-31-2021 03:36 PM #4
- Join Date
- Apr 2014
- Reputation
- 10
- Posts
- 9
@Ecmslee : I have had the same issue with all uefi : 0211, 0402 and with the latest 0504
@Kelutrel : I do have a M.2 SSD (WDBLACK SN850 1TB). I have removed the film of the thermal pads, and the temperature is normal at around 54°C.
My graphic card is EVGA 3080 ti FTW3 and is not overheating. Plus I have never crashed while gaming, the crashes always occur when the system is pretty idle, or when I'm watching videos.
Your idea of suspecting the M.2 SSD or the graphic card is indeed good, but remember that when I don't use D.O.C.P the system is rock stable.
I don't see how using D.O.C.P will make the SSD or the graphic card overheat ? especially when the issue never happens while stress-testing the system, but rather when it's almost idle.
This is why the title of my post is "strange unstability issue". I have never encoutered such problem and that's why I'm completely lost on this one. And it's a shame because this setup cost me a lot of money.
12-31-2021 04:21 PM #5
- Join Date
- Jan 2019
- Reputation
- 68
- Posts
- 75
@fcueto Actually in your initial message you said that you tried to disable D.O.C.P, and also tried to lower the ram frequency, but the issue was still there. This is why I discarded your ram as the source of the issue.
It may also look like a memory leak that slowly grows up and causes problems after 2-3 days of uptime. You may want to check, from the task manager CPU and Memory performance pages, the number of Handles and the Paged/NonPaged pool after a day or two, as it may be that a driver or an application is somehow continuously allocating resources without freeing them.
12-31-2021 11:09 PM #6
- Join Date
- Apr 2014
- Reputation
- 10
- Posts
- 9
@Kelutrel : at stock (ie ram freq = 1333mhz), the system is stable. At higher frequencies (I only tried 1600 and 1800mhz), the system is unstable.
I don't think the issue is driver related because if it was, I would encounter the issue @stock frequency.
That's why I think it's related to the frequency but what I don't undestand is that all stress tests are passing (I tried aida benchmark, testmem5, Karhu RAM Test and MemTest Deluxe). Actually the system seems perfectly stable until it crashes like I described, often when idling or watching youtube videos.
01-01-2022 02:20 AM #7
D_BRASCO PC Specs Motherboard ASUS ROG CH8DH Processor AMD Ryzen 9 5950x Memory (part number) 64GB G.Skill F4-3600C16D-32GTZNC Graphics Card #1 NVIDIA Geforce 3090 FE Storage #1 Seagate FireCuda 520 2TB PCIe Gen4 Storage #2 Seagate FireCuda 520 2TB PCIe Gen4 CPU Cooler EK Custom loop Case Lian Li Dynamic 011 XL ROG Power Supply Corsair AX1200I Keyboard Corsair K95 Mouse Elecom HUGE Headset/Speakers Logitech Z5500 OS Windows 11 PRO Network Router Asus RT-AC1900P Accessory #1 Toshiba HDWG180 (5090A05KFBEG) Accessory #2 Hitachi HDS724040ALE640 (PKV331P1GN0EDY)
- Join Date
- Aug 2020
- Reputation
- 10
- Posts
- 19
Have you tried to skip setting the bios to DOCP and manually enter the DOCP setting in the memory setting. I've read some posts where that worked,
01-01-2022 03:43 AM #8
RedSector73 PC Specs Laptop (Model) FA506IU-AL130T x 2 Motherboard ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 3900X 12-Core Processor Memory (part number) 4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die Graphics Card #1 Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC) Sound Card Arctis DAC Monitor Asus ROG Swift PG348Q Storage #1 ADATA SX8200PNP 1TB Storage #2 2 x Samsung SSD 840 EVO 250GB CPU Cooler Coolermaster Liquid Pro Master 360 Case EVGA DG-87 Gunmetal Grey Gaming Case Power Supply EVGA SuperNOVA G2 750W Gold Power Keyboard Corsair K95 RGB Platinum Mouse Corsair Gaming Sabre RGB Gaming Mouse Headset ARCTIS Pro Wireless Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large OS Windows 11 64bit Pro Network Router PfSence Intel i5-10210U 6 Port Accessory #1 TP-Link Gigabit 8&6 Port Switches
- Join Date
- Apr 2018
- Reputation
- 65
- Posts
- 1,309
01-03-2022 08:45 AM #9
ImpetuousRacer PC Specs Motherboard Asus ROG Crosshair VIII Extreme Processor AMD 5950X Memory (part number) G.SKILL Trident Z Royal Elite F4-3600C14Q-64GTESA Graphics Card #1 Asus ROG Strix 3090 OC Monitor Samsung CRG9 C49RG90S 49" Storage #1 FireCuda 530 4TB Storage #2 FireCuda 530 4TB CPU Cooler Noctua NH-D15S chromax.black Case CoolerMaster H500M Power Supply SeaSonic Prime TX-1000 Keyboard Logitech MX Keys Mouse Logitech MX Master 3 Mouse Pad HyperX Fury S Pro XL Headset/Speakers Creative GigaWorks T20 Series II OS Microsoft Windows 11 Pro Network Router Ubqiuiti Dream Machine Pro SE
- Join Date
- Oct 2019
- Reputation
- 10
- Posts
- 20
I've just come from a Crosshair VIII Hero WiFi and upgraded to a Crosshair VIII Extreme. Setup worked perfect with the Hero. Same EXACT components moved to this board and I can't get it to boot with DOCP enabled. Had to drop from 3600 down to 3466 to get it to post.
Not sure if I have defective board, or maybe BIOS is just immature?
02-20-2022 04:21 PM #10
- Join Date
- Apr 2014
- Reputation
- 10
- Posts
- 9
OK after several weeks of investigations I finally caught the culprit. It was not a hardware problem but a software problem with Asus Armoury Crate. As soon as I use the fan monitoring I got these strange crashes I described.
I have read many forum posts about the exact same crashes with Nzxt Cam but in the end, it's exactly the same with armoury crate. I wonder if the bug could come from the uefi ?
