Results 1 to 6 of 6
    ROG Guru: Yellow Belt Array Terepin PC Specs
    Terepin PC Specs
    MotherboardROG STRIX B550-F GAMING
    ProcessorAMD Ryzen 5 5600X
    Memory (part number)F4-3200C14-8GFX
    Graphics Card #1ASUS TUF GeForce RTX 3070 Ti OC
    Sound CardSupremeFX S1220A
    MonitorLG 27GL850
    Storage #1Samsung 970 Evo Plus
    Storage #2Western-Digital WD Blue
    CPU CoolerNoctua NH-U14S
    CaseFractal Design Define R6
    Power SupplySeasonic Prime TX-850
    Keyboard Razer Huntsman V2 (Red Switch)
    Mouse Razer Basilisk V3
    Headset Razer BlackShark V2
    Mouse Pad Razer Gigantus V2
    OS Windows 11
    Network RouterASUS RT-AX58U
    Accessory #1 Razer Base Station V2 Chroma
    Accessory #2 Razer Mouse Bungee V2 Chroma
    Nov 2014
    174
    ROG Strix Scope RX emits high pitched noise
    I love the keyboard, but it's loud! The sound is being emitted regardless of the RGB light and if I set the light to maximum there is another noise that makes it even louder. I cannot make this keyboard silent no matter what I try. I already replaced it it twice and all of them has the same issue. In fact, I even tried cheaper TUF Gaming K3 and it has the same issue. What gives? The previous generation didn't suffer from this problem.
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z - 3600MHz 16-16-16-36-2T
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Keyboard ROG Falchion NX / Strix Flare II
    Mouse ROG Chakram X/Chakram Core/Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    372
    17,221
    Hi Terepin,
    Trying with three keyboards all with the same issue would say it's not the keyboards.
    Have you tried different usb ports?
    Does the high pitched sound occur when the RGB is off?
    Terepin PC Specs
    MonitorLG 27GL850
    OS Windows 11
    Nov 2014
    174
    Yes. I tried different USB ports, even different computer. The noise is being emitted even when light is off.
    Nate152 PC Specs
    MonitorHP ZR30w
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    372
    17,221
    Thank you,
    Is Armoury Crate fully updated?
    If yes, try resetting your keyboard by pressing Fn+Caps for 15 seconds.
    Terepin PC Specs
    MonitorLG 27GL850
    OS Windows 11
    Nov 2014
    174
    Tried it. No dice.
    Nate152 PC Specs
    MonitorHP ZR30w
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    372
    17,221
    Thank you,
    I've never experienced a keyboard with a high pitched noise, maybe my ears aren't as good as yours or my pc is too loud.
    Does your ROG Strix Scope work fine other than the high pitched noise?
    What firmware version are you using?
    I was searching around to see if I could find anything and came across these steps to resolve it, no guarantees but worth an attempt.
    Right click on the taskbar then select Taskbar settings
    Click Home then select Update and Security
    Select Troubleshoot on the left side
    Click Keyboard then Run the Troubleshooter
    Click Home then select Ease of access
    On the left side, Click Keyboard
    Turn off Filter keys, you may also try to turn off other options there
    Right Click the Start icon on the lower left of your screen
    Choose Device Manager
    Expand Keyboards then Right click the keyboard device
    Select Uninstall this device then Restart your PC
