Results 1 to 5 of 5
    New ROGer Array
    Dec 2021
    2
    ASUS strix 3060 OC 12GB - Blinking red lights about PCIE power
    I am using a ASUS strix 3060 OC 12GB, with the 850W Thor. I used the PCIE braded power cables.
    Not sure why the light is blinking and what is the cause.
    Anyone have any official documentation on the blinking?
    I saw some fixes that need to use GPU Tweak, but I want to know the cause.
    ROG Member Array
    Jan 2022
    6
    Asus' cards don't come with any documentation that I could find. My 3080 came with basic installation instructions only.
    Anyway, try using as many separate PCIE/VGA cables as is required from your PSU to the card; for example, if the card requires 3x8 PCIE/VGA connections, use 3 separate cables coming from your PSU to your card. In other words, don't use the pig tails that may be coming off of any one cable.
    I only get the red light if one of the 3x8 connections on my card is missing. I also have a 850W PSU 80+ Gold.
    New ROGer Array Ribellu PC Specs
    Ribellu PC Specs
    MotherboardAsus Maximus Z690 HERO
    ProcessorI7 12700KF
    Memory (part number)Corsair Vengeance DDR5 2X16Gb 5200Mhz 38/38/38/74
    Graphics Card #1Asus ROG-STRIX-RTX3080TI-O12G-GAMING
    MonitorAsus VG27AQ
    Storage #1SSD Samsung 970 EVO Plus 1T
    Storage #2SSD Samsung 960 EVO 500gb
    CPU CoolerMSI MAG CoreLiquid C240
    CaseThermaltake Commander C31 TG
    Power SupplyCorsair HX850
    Keyboard Razer Huntsman Tournament Edition
    Mouse Razer Bazilisk V2
    Headset/Speakers Hyper X Cloud Alpha
    OS Windows 10 Pro 21H2
    Dec 2021
    50
    100
    Quote Originally Posted by BryNeedsSleep View Post
    I had this problem for the first time after the last BIOS update of my Z690 HERO after some research, I found the solution, you just have to unplug the power cord for about 5 minutes, put it back and flashing red lights will be gone . (Asus Strix 3080Ti 12G-OC)
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1ROG-STRIX-LC-RTX3090TI-O24G-GAMING / Asus Turbo 2080 ti in SLI
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / ROG Ryujin 360
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 2, Noctua 120mm 3000 RPMx3/ Noctua 140 mm 3000 RPM x 3
    Mar 2019
    31
    453
    Getting this now on a Strix 3090Ti. It was fine for a couple weeks and then suddenly the red light starting flashing today. I have no idea what the reason is. The PSU is a beefy Corsair 1600I.
    Could the cable have suddenly come loose or something? Weird.
    ROG Guru: Green Belt Array ahfoo's Avatar
    Jan 2020
    161
    628
    To solve this issue, you just need to turn off the swtich of the power supply and unplug the power cord for a couple of minute. And insert back the power power cord, turn on the swtich and power up your system. That what I do for my system.
    Edit: It always happen if have installed any Asus Tweak software.
Tags for this Thread
