01-07-2022 08:58 PM - last edited on 03-06-2024 10:30 PM by ROGBot
03-11-2022 07:06 AM
03-11-2022 07:14 AM
Da-BOSS wrote:
You might have a bad batch... I have exactly the same laptop that you have ASUS TUF A15 FA506IU laptop and I don't suffer from this problem... maybe might give a new BIOS update a try.. it just got released 2 days ago 🙂
03-15-2022 06:59 PM
yhdog wrote:
Hi, I have tried the BIOS 318 released 2 days ago but still the same issue.:(
Hmm, you mean you have tested Rainbow Six Siege (1080p Low Preset) benchmark with no CPU problem?
03-15-2022 07:15 PM
Da-BOSS wrote:
Yes, exactly I have tested this without problem. I guess your only way is to try this APU Tuning Utility and adjust your TDP Fast/Slow limits and try again.
03-16-2022 04:39 AM
yhdog wrote:
Actually I have tried RyzenADJ, Renoir Mobile Tuning and the tool you mentioned. Adjusting TDP Fast/Slow limits works for seconds before the limits are overwritten by BIOS or other ASUS things. The CPU Power breaks the 13 Watts limit only when I set a reapply cycle (maybe 3 seconds) for these 3rd-party tools.
I still hope ASUS can do some research and give a response, after all I don't want to rely on 3rd party software to correct things that should be the responsibility of ASUS. 😉
03-16-2022 06:10 AM
Da-BOSS wrote:
That's definitely true about ASUS responsibilities but as a last resort... 3rd party software will help always.
Did you make sure that RyzenADJ script with repeat delay of [repeatWaitTimeSeconds = 5] is set to avoid getting a reset values with $monitorField = "fast_limit" line included?
