Results 1 to 3 of 3
Thread: PG279Q Monitor Artifacts
01-12-2022 10:05 PM #1
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 3
Hey,
My trusty monitor started to show signs of possibly dying soon.
When I turn on the monitor on the first time, a vertical swirly line of white artifacts appear on the screen.
These artifacts are gone within a minute after the monitor has heated up.
Otherwise the monitor works just as normal, nothing out of the ordinary, however these cold-start artifacts made me wonder if the monitor is really dying soon.
Anything I can do about it? repair?
It's a damn good monitor and I didn't think it would be dying within less than 4 years of use.
Warranty has gone less than a year ago..
-Kondekka
01-12-2022 10:09 PM #2
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 3
01-12-2022 11:20 PM #3
xeromist PC Specs Laptop (Model) Intel NUC laptop LAPQC71D Motherboard ROG Crosshair VIII Dark Hero Processor AMD 5800X Memory (part number) 32GB G.Skill Ripjaws V 3600 Graphics Card #1 ROG Strix RTX3090Ti Sound Card Sound Blaster Z Monitor AORUS FV43U Storage #1 Samsung 970 Pro 512GB CPU Cooler Custom loop Case BeQuiet Dark Base Pro 900 V2 Power Supply Corsair HX1000 Keyboard ROG Strix Flare II Animate Mouse ROG Chakram X Headset Steelseries Arctis Pro Wireless Mouse Pad ROG Scabbard Headset/Speakers Logitech z906 5.1 Network Router pfSense/OPNsense
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,615
Looks like a problem with the circuitry rather than the panel so if it does die on you at some point you could probably get the internals from a donor monitor with a broken screen if you keep an eye out on Ebay. Also a trained technician may be able to do component level diagnosis and replacement. Sometimes it's as simple as a single capacitor replacement.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
