Results 1 to 9 of 9
01-13-2022 02:04 PM #1
- Join Date
- Nov 2013
- Reputation
- 38
- Posts
- 46
ROG DELTA S Animate Default EQ Question
This was the EQ setting after first run. Resetting to this mode didn't change the non-zero settings.
Is this the actual "FLAT" curve, or is this just for show? Should I turn the custom EQ mode off for the "flat" response? Thanks c;
01-14-2022 04:01 AM #2
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 367
- Posts
- 8,343
Off would be the flattest. I've heard the Delta S is actually the ROG product with the flattest response but ironically most people aren't used to flat and don't like it. So the "Default" is going to be what the engineers think most people will find pleasing.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
01-14-2022 05:33 PM #3
- Join Date
- Nov 2013
- Reputation
- 38
- Posts
- 46
01-20-2022 12:26 PM #4
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z - 3600MHz 16-16-16-36-2T Graphics Card #1 Titan Xp - EKFC waterblock Graphics Card #2 Titan Xp Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply PCP&C Turbo Cool 1200w Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 347
- Posts
- 17,077
01-22-2022 12:06 AM #5
- Join Date
- Nov 2013
- Reputation
- 38
- Posts
- 46
Thanks for telling me
Although apps like Tidal don't follow any sort of custom sound settings on any of my speakers -- inside and outside of AC.
Spotify does change, though, but I could not discern the differences between EQ 'off' and your flat one with the custom 32 and 16k Hz settings.
Are you suggesting that this delta S only has peakiness at those 2 ranges, hence the reduction?
01-22-2022 12:42 AM #6
- Join Date
- Nov 2013
- Reputation
- 38
- Posts
- 46
While I wait for your comments, I have another burning question...
How does one properly use the MQA renderer xd?
I even made a report on the latest AC feedback thread (post #105) that was edited as 'fixed' since I thought this whole thing needs to accompany each other -- software AND hardware decoding...
The first couple of searches, though, made me think that I had to enable -- in Tidal -- the MQA Passthrough option. But by this, Armoury Crate always showed N/A for my MQA status... hence the report.
Now I'm reading that this renderer can FULLY 'unfold' MQA tracks...
Which one is right?
01-22-2022 02:22 PM #7
- Join Date
- Feb 2013
- Reputation
- 347
- Posts
- 17,077
The ROG Delta S Animate has the renderer. Renderer + a Core Decoder Device which Tidal acts as, gives us full decoder sound quality with all three unfolds for the best possible sound.
From Tidal:
TIDAL has partnered with MQA (Master Quality Authenticated) to create TIDAL Masters and deliver guaranteed master recordings directly from the master source to TIDAL members in Master Quality audio. With unrivalled quality, clarity and depth delivering all file sizes (up to 24 bit / 352kHz) and using no more bandwidth than a CD quality (16 bit / 44.1kHZ) file, Master Quality audio is the only format that guarantees music fans that they are listening to the original master recording – exactly as the artist intended the track to sound.
Apparently, we lose EQ control because we're to listen to how songs are originally recorded, if we alter them with an EQ they're no longer original. Tidal is fussy with MQA, we can't record MQA songs either.
Here's a short video to show MQA is on in Armoury Crate, make sure Passthrough MQA is set to off.
01-22-2022 06:03 PM #8
- Join Date
- Nov 2013
- Reputation
- 38
- Posts
- 46
So my original setup was the correct one after all. Thanks for confirming
01-22-2022 08:14 PM #9
- Join Date
- Feb 2013
- Reputation
- 347
- Posts
- 17,077
You're welcome,
The ROG Delta S Animate with MQA is new to me too, but if you have any other questions I'll try to help.
