Results 1 to 5 of 5
01-13-2022 08:08 PM #1
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 3
Display Port On Motherboard: No signal
ASUS TUF Gaming Z590 Plus Gaming Motherboard (ATX, 11th/10th Gen Intel Core, LGA 1200 Socket, DDR4, PCIe 4, CFX, M.2 Slots, USB 3.2 Gen 2, DP/HDMI, Mystic Light
Gigabyte GeForce GTX GV-N1080G1 GAMING-8GD
G.Skill Ripjaws V Series 32GB (2 x 16GB) 288-Pin SDRAM (PC4-25600) DDR4 3200
Intel Core i5-10600 (base stroke: 3.30GHz; socket: LGA1200; 65 watt
The first time that I started the new motherboard, my monitor was connected to the DP output on the MB. Signal was fine. After setting up CSM for Legasy as instructed, there was no longer a signal from the port. I had to connect directly to the GPU. What did I do wrong? Is there a way to activate the DP on the MB? Thank You.
01-14-2022 03:32 AM #2
- Join Date
- Apr 2019
- Reputation
- 51
- Posts
- 1,212
Hi Wackadoodle,
Do you use the same DP cable when connected to MB or GPU?
If you disable CSM again, can you get the signal through DP output on the MB?
Are the bios all default settings except CSM enabled?
May I have the bios version?
Are you able to set Primary Display as iGPU in bios? (Advanced/System Agent (SA) Configuration/Graphics Configuration/Primary Display)
01-14-2022 10:46 PM #3
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 3
01-17-2022 04:49 AM #4
- Join Date
- Apr 2019
- Reputation
- 51
- Posts
- 1,212
Hi Wackadoodle,
If you have the graphics card installed, and only connect one monitor, I suggest use the DP from the graphics card.
01-21-2022 04:58 PM #5
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 3
OK, I understand now. I went to Ton Hardware Forum. You are correct the DP on the MB is only for those who don't have a GPU Card. The card is the best output. Thanks. I was just curious. Now I am Happy!
