Is there a way to measure backhaul speed for Asus Mesh router?
ahfoo
Hi, Is there a way to measure backhaul speed for Asus Mesh router?
AX11000 main router--GT-AC5300 (Mesh via wired}. Need to know if there is a way to test the GT-AC5300 as a backhaul? Thank you.
Saltgrass
I think it is pretty much determined by what is being used as the Backhaul. If you are using Ethernet, probably 1 Gbps.. It should show such info in the user interface if you look at the Mesh setup.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
Saltgrass
Of course, this would depend on the Router being used.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
