Results 1 to 2 of 2
    ROG Junior Member Array
    Mar 2018
    4
    Strix GL503 - dedicated GPU for external monitor?
    Hello,
    I bought a monitor capable of 4K otput @ 60FPS via HDMI for my laptop (Strix GL503, it has a GTX 1050 which should be capable for that - note that I do not intend to game on this thing, just office productivity work) but the best I can get is 4K @ 30FPS and it's through Intel HD 630 and the image displayed on the monitor is choppy. I'm running Windows 10 and cannot for the life of me find a setting which would allow me to force the dedicated GPU for video output instead of Intel graphics.
    Any help guys?
    Kind regards!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    MotherboardROG Crosshair VIII Dark Hero
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Power SupplyCorsair HX1000
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    411
    8,472
    The GL503VD has an HDMI 1.4 port which is limited to 4k 30hz. The GPU does not matter because the port is the limitation. You can run a higher refresh but you will have to lower the resolution. Depending on the monitor 1920x1080 may look clear for desktop work because it is exactly 1/4 of a 4k display.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
