Results 1 to 2 of 2
01-17-2022 02:31 PM #1
- Join Date
- Sep 2020
- Reputation
- 10
- Posts
- 11
realtek audio driver installation question
I installed audio driver from viii hero site, i opened asusetup.exe instead original setup.exe, it first installed vc_redist because it is freshly installed windows, and after that nothing happened, no confirmation or anything that audio driver is installed, but i checked device manager and it says it is installed, along with control manager. Is it normal behavior?
01-17-2022 03:47 PM #2
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z - 3600MHz 16-16-16-36-2T Graphics Card #1 Titan Xp - EKFC waterblock Graphics Card #2 Titan Xp Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply PCP&C Turbo Cool 1200w Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 347
- Posts
- 17,057
Hi Shocker,
You can use either Asus setup or original setup.
Open Asus setup the first time to extract the files, click Asus setup again to install.
