Results 1 to 10 of 62
12-21-2021 04:24 PM #1
- Join Date
- Dec 2021
- Reputation
- 10
- Posts
- 2
ROG Claymore II
Hello guys. I just got ROG Claymore II keyboard [RX blue], and it's AWESOME! But i can't seem to update firmware. I will put the message i get from ARMORY II V5 in attachments. I'm doing what it asks, but it's always the same message. I don't intend to use this keyboard in wireless mode, only over usb (Type-c to Type-c, since my motherboard have a Type-c port). Thanks for any help! <3
12-22-2021 04:04 PM #2
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card ROG SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,419
Hi 420.69.1337
Welcome to the ROG forum.
This worked for the ROG Chakram wireless mouse, maybe it will work for your wireless keyboard too.
Connect the dongle to a usb port and the ROG Claymore II to another usb port and try updating.
Does this let you perform the update?
12-23-2021 12:55 PM #3
- Join Date
- Dec 2021
- Reputation
- 10
- Posts
- 2
12-23-2021 06:13 PM #4
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,419
You're welcome !
Good to see you're updated.
How are you liking your ROG Claymore II and Armoury Crate?
01-05-2022 09:41 PM #5
matkocore PC Specs Motherboard ASUS ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 5900X Memory (part number) G.Skill F4-3600C16-1 64 GB Graphics Card #1 ASUS ROG STRIX RTX 3090 GAMING OC 24G Monitor ASUS ROG PG279QM Storage #1 WD Black 4 TB Storage #2 Samsung SSD 970 EVO Plus 2TB CPU Cooler ASUS ROG Ryujin II Case ASUS ROG Strix Helios Power Supply ASUS ROG Thor 1200P Keyboard ASUS ROG Claymore II Mouse ASUS ROG Gladius II Origin Headset/Speakers SoundBlaster Katana OS WIin 11 PRO x64
- Join Date
- Dec 2021
- Reputation
- 10
- Posts
- 3
01-06-2022 01:54 AM #6
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,419
Hi matkocore,
If you are connecting the dongle to a usb port on your pc and connecting the ROG Claymore II to your pc with the cable (preferably two motherboard usb ports), you are doing it correctly.
If it's still not updating, you could try reinstalling Armoury Crate. Use the Armoury Crate uninstall tool from the ASUS Support Center, then reinstall it again.
Select your OS then click "See All Downloads."
https://www.asus.com/us/supportonly/...Desk_Download/
You can let the cable and dongle connected with the switch on during reinstallation.Last edited by Nate152; 01-06-2022 at 02:13 AM.
01-06-2022 02:13 AM #7
MrAgapiGC PC Specs Motherboard Asus Maximus XI Code Processor 9900K Memory (part number) CMK32GX4M4B3600C18 Graphics Card #1 STRIX-GTX1080ti-O8G-GAMING Monitor AOC AGON AG2701QX (2) Storage #1 Samsung 960 EVO 256GB Storage #2 Kingston Savage 500GB CPU Cooler Nzxt X74 360mm AIO Case Nzxt H700 Power Supply EVGA 850 G2 Keyboard Logitech G810 Mouse Asus Spartha Headset Hyper X Cloud Revolver S Mouse Pad Hyper X Fury S 900mx420mm Headset/Speakers Logitech Z337 OS Windows 10 64btis Network Router TpLink Archer C9 Accessory #1 EKWB FANs all of them
- Join Date
- Nov 2011
- Reputation
- 28
- Posts
- 1,852
mmmm
Let me thinkLearn, Play Enjoy!
01-06-2022 10:25 AM #8
- Join Date
- Dec 2021
- Reputation
- 10
- Posts
- 3
Hello Nate,
Thanks for the reply.
Yes i tried updating with both the keyboard connected to USB port and with the dongle connected as well.
Also tried to reinstall AC software as well.
Its just the same pop up message.
Its weird, FW update on other HW and peripherals was without any problem.
Thanks!
01-06-2022 12:20 PM #9
- Join Date
- Dec 2021
- Reputation
- 10
- Posts
- 3
Hi guys,
So i managed to fix it, but it is unclear what helped.
I did clean uninstall/install again.
Then i went to the update center click on update and had the same issue.
Then i hit update again and right after clicked on check for updates and during the loading checked several pop ups appeared reagrding the fw update.
After the checked was finished the update loading bar was in progress and finally the fw keyboard update was done.
Really bizarre issue.
Thanks for tthe replies and have a nice day!
01-06-2022 03:42 PM #10
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,419
You're welcome,
Thank you for reporting and good to hear you're updated.
