Results 1 to 2 of 2
    New ROGer Array
    Dec 2021
    34
    Help me with cpu voltage please
    Hey!
    Asus Z690 Apex, Core i9-12900K.
    I have the adaptive voltage for the processor set and AI overclocking mode enabled. The memory is set to XMP.
    I would like the processor voltage to be low in idle time (working in Windows in a browser, watching a video, and so on). At the same time, in a heavy load (for example, when the turbo is activated) or when you play (and so on), the processor voltage rose to the required level (for example, as it is now set - up to 1.321 volts).
    How to do it for safe ?
    ROG Enthusiast Array Englishman.Xperia PC Specs
    MotherboardASUS RoG Strix B450-E Gaming
    ProcessorAMD Ryzen 7 2700X
    Memory (part number)Corsair 16Gb DDR3200 LPX
    Graphics Card #1ASUS RoG Strix RX480 OC
    MonitorASUS RoG XG27VQ
    Storage #1Corsair MP510 480gb
    Storage #2AMD R7 240Gb SSD
    CPU CoolerASUS RoG Ryujin 240
    CaseCorsair Obsidian 450D
    Power SupplyASUS RoG Strix 750Watt
    Keyboard ASUS RoG Strix Flare
    Mouse ASUS RoG Gladius II Origin
    Headset ASUS RoG Strix GO 2.4
    Mouse Pad ASUS RoG Sheath
    Headset/Speakers Logitech 5.1
    OS Windows 10
    Network RouterASUS Lyra Mini
    Accessory #1 ASUS RoG ARION
    Feb 2021
    47
    I wouldn't be doing like that. Plus, if you don't OC like a maniac, just go for negative offset anyway. You will get better temps too.
    You should always do it via BIOS and find the offset CPU voltage. Then fiddle with it, small increments with negative offset til you find the sweet spot.
    If you are interested, here's the video.
    https://youtu.be/yVFjvizChrw?t=437
