Results 1 to 1 of 1
    New ROGer Array Echo8ict PC Specs
    Echo8ict PC Specs
    MotherboardASUS ROG CROSSHAIR VIII DARK HERO
    ProcessorAMD Ryzen 9 5900X
    Memory (part number)G.Skill Trident Z Neo 32GB (4X8) 3600mHz
    Graphics Card #1Asus ROG Strix GeForce RTX 3080
    MonitorAsus TUF Gaming VG279QR
    Storage #1Samsung 980 Pro PCIe 4.0 NVMe M.2
    Storage #2Samsung 870QVO 2.5 SATA
    CPU CoolerASUS ROG Ryujin 360
    CaseLian Li Lancool II
    Power SupplyAsus ROG Thor 1200W Platinum
    Keyboard Asus Claymoore II
    Mouse Asus ROG Strix Impact II
    Mouse Pad Asus ROG Sheath
    OS Windows 11 Pro
    Accessory #1 Asus ROG Strix Arion
    Dec 2021
    33
    4
    VGA led stays on, Crosshair VIII Dark Hero
    System is:
    Asus ROG Crosshair VIII Dark Hero MB
    AMD Ryzen 9 5900X
    G. Skill Trident Z Neo 3600mhz (4X8)
    Asus Strix RTX 3080 GPU
    Asus Thor 1200W PSU
    Problem is:
    When I power on the computer, BIOS loads but the monitor never comes on and sometimes the white LED on the motherboard stays on (VGA).
    Back story:
    Once upon a time, less than 3 weeks ago, all was well and working. I decided I wanted the Asus Helios case so all I had to do was transfer everything over to the new case. I did change out the Corsair LL 120 fans on the Ryujin 360 AIO to Lian Li Unifan AL120's. I also bought a new Asus Strix Riser Cable. I got in a hurry and made a bonehead mistake and plugged the USB 2.0 cable from the Ryujin onto the wrong set of pins, and I believe it shorted out the AIO. Now my system is not happy. At first when I would start my computer, BIOS would load, error out and reload just fine and go to windows. Without a cooler on the CPU I couldn't leave my pc on for long. After troubleshooting the AIO I purchased a new Strix 360 AIO and tried again. Now sometimes the BIOS/POST would cycle thru 2 to 3 times before it hangs. Sometimes the monitor would come on showing the BIOS screen, and sometimes it would never come on. These components are all new, built in a Lian Li Lancool II December 20th and everything worked great.
    Things I have tried:
    I thought maybe my brand new Strix RTX 3080 went bad, so I tried my old GTX 1070 and received the same results. So thankfully I do not believe my new 3080 is bad. I bought custom CableMod Promesh cables, and thought maybe they are bad, so I tried the cables that came with the Thor PSU. Still doesn't work. I could never get the riser cable to work so I took it out of the equation. I decided maybe the PCI-e slot went bad. So I tried the 3080 in slot 2, but still no monitor and the white LED on the MB stays on (VGA). * I am thinking this MB is done, so I'm thinking of buying a new one. Any ideas or suggestions? I did a search but couldn't find any related information.
    Thank you in advance.
Tags for this Thread
