Results 1 to 10 of 10
Thread: Trouble with GK2000 RGB
02-10-2022 07:19 PM #1
lmc0pl PC Specs Motherboard Asrock X79 EXtreme 11 Processor Xeon E5-2630 V2 Memory (part number) 4X4GB Corsair XMS 3 Graphics Card #1 Gigabyte GTX1070 G1 Rock Monitor Omen X35 Storage #1 Ocz Trion 150 Storage #2 5x2TB Case Zalman Z9 Power Supply Ocz ModXstream-PRO 600w Keyboard GK2000 RGB Mouse G600 Headset ISK and few logitech Mouse Pad Razer Firefly Headset/Speakers Harman-Cardon Soundsticks OS Win 10 x64
- Join Date
- Nov 2021
- Reputation
- 10
- Posts
- 5
Hi, i have a trouble with GK2000 RGB. I buy it and using some time without software and was all ok. One day i want to try software but get info if i need upgrade the firmware. So i click ok. After this, first crashed armory crate proces(i was using gladius, and need this software). After this, updater crashed too and keyboard stop working. After restart pc, keyboard working but havent backlight, additional button and volume control dont working too. Support wont help, just say try again. So i trying and trying and getting error on random block. After a few time, program even cant read "Current FW version". My warranty end few month ago. And trying on another pc, on fresh windows, different usb ports. Any version fw updater wont work. I dont see any info if i need to unistall armory crate before update my GK2000. I really need help, beacouse i dont know what now? Anyone can help me please. Sorry for my language. Greatings.
02-12-2022 08:30 PM #2
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,411
Hi Imc0pl,
Welcome to the ROG forum.
The ROG Horus GK2000 RGB keyboard isn't supported with Armoury Crate/Aura Sync.
Uninstall your current RGB software version and install version 0.97, select your OS, it's the first download.
https://rog.asus.com/keyboards/keybo...pdesk_download
After installing, try updating the firmware.Last edited by Nate152; 02-12-2022 at 08:41 PM.
02-13-2022 05:53 PM #3
- Join Date
- Nov 2021
- Reputation
- 10
- Posts
- 5
Hi and thx for your answer. Maybe my message wasn't enought clear. I already trying all of version of software, 97 too. Support say me if i should be patient and trying to update. But now, after trying many times, the software doesn't recognize the keyboard. Instead of the name, I see the IAP. Previously, after the first failed attempt, the keys worked in addition to m keys, fn, volume and backlight controls. However, after these attempts, some parts do not work or are delayed. When I use capslock on another keyboard, the rog logo lights up, numlock works. The backlight is turned on in a few keys, but only after turning on the pc for literally a moment. The more you try to update, the worse it gets. At the beginning it was still usable somehow, now it is not. I needed ArmoryCrate because I was using a gladius mouse. Not anymore, neither do I have ACrate. It all started with a process crash, armory crate service something, I don't remember exactly. After that, the updater itself stopped responding. An error has occurred and the keyboard is not working since then and the updater cannot read the software version. I have tried on a different pc, clean system and always the same, even worse as I wrote earlier. If I knew armory crate was causing the problem then I wouldn't update and use as before. There is some way to clear the keyboard firmware, or force a clean install. Anything that will help? It's a bit annoying to be left with a broken keyboard that wasn't cheap. The process stopped by itself, I didn't do anything then. I am attaching screens with errors that show up when trying to update, later the program no longer recognizes the keyboard until disconnecting the keyboard or restarting pc.. I would ask for help. Thank you.
02-13-2022 10:39 PM #4
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,411
Ok,
To reset your keyboard press and hold the Fn + ESC keys for 10-15 seconds.
Did you use the Uninstall tool to uninstall Armoury Crate? You'll want to use this to remove all services/processes and any corrupted files.
Select your OS then click "See All Downloads", it's the second download.
https://www.asus.com/us/supportonly/...Desk_Download/
Try updating your keyboard after using the Armoury Crate uninstall tool.
If this doesn't get it to update, a windows reinstall may be needed.
If you do reinstall windows, update your keyboard first then install Armoury Crate.
02-16-2022 05:09 PM #5
- Join Date
- Nov 2021
- Reputation
- 10
- Posts
- 5
Hello, I have already checked the solutions you propose. Unfortunately, no results. Reset does not work, use of the fn key is not detected at all. I'm afraid I need something to flash the firmware, not an updater. Support says the software is not for public use, is there any other option for me to get it? The service will not repair it without a guarantee, even for a fee. I could try to reset via the pcb pin, but I don't know whether to provide ground(-) or voltage(+) there.
02-16-2022 05:19 PM #6
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,411
Unfortunately, if the software is not for public use, we can't have access to it.
I will suggest to uninstall your keyboard from device manager, restart your pc and let it set up as a new device and try resetting/updating it again.
02-21-2022 08:32 PM #7
- Join Date
- Nov 2021
- Reputation
- 10
- Posts
- 5
Its not helping too. Same error. What now?
02-21-2022 10:57 PM #8
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,411
Sorry to hear, I'm not sure why it doesn't want to update.
I'm pretty much out of suggestions short of reinstalling windows, and even then I can't guarantee 100% this will get it to update, but you could try it as a last resort.
An easy solution would be to get a newer ROG keyboard that is compatible with Armoury Crate, then you can control/update everything from there.Last edited by Nate152; 02-21-2022 at 11:48 PM.
02-23-2022 05:58 PM #9
- Join Date
- Nov 2021
- Reputation
- 10
- Posts
- 5
Hello, I have tried to update multiple times but I keep getting the same error. The system is new, I also checked on other pc. Keyboard reset does not work. It's not fair that the keyboard broke due to a bug beyond my control. There is no option to undo this update? Or maybe you know a program that can be used to upload the software? MSI provides such a keyboard program on this microcircuit, why asus not? I tried the reset via the pcb pins, but it also doesn't work. I can see that there is a boot option, so you can upload the software somehow. Maybe some unofficial program, whatever. Maybe something beyond the official distribution channels? The keyboard wasn't cheap and I can't afford to buy something in this class now. Please, have mercy.
02-25-2022 05:33 PM #10
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,411
Ok,
Try version 1.00 and see if it will update.
https://www.asus.com/supportonly/ROG...Desk_Download/
