Asus Claymore II battery percentage issue
emkdrl07
Hey, i ran into another problem today. I charge the product fully (100%) and disconnect the cable, when the pc is turned off and on, the battery percentage appears as 81%.
92122
92123
MasterC
Community Admin
Community Admin
How long before you boot up again? Do you mean that the keyboard loses 19% almost instantly?
After shutdown, did you turn the keyboard off using the power switch?
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
drbtt
92122
92123
hi emkdrl07, im facing the same issue but also during charge.
here my related thread: https://rog.asus.com/forum/showthread.php?127666-Asus-Rog-Claymore-II-battery-charge-and-discharge-i...
Also, it's random because after some charges, sometimes the percentage drops as you described but sometimes works well, it's really weird but started happening since january firmware update.
Today i got a new firmware update (20.32.02), so i will keep checking if its solved or not.
seems the lastets firmaware (20.32.02) does not solve the issue, charged from 70% to 100% to try, but again dropped mostly instant to 87% this time.
