Results 1 to 1 of 1
    New ROGer Array
    Feb 2022
    2
    Thumbs up ROG Fan Controller Fan Whine
    My fans (EKWB Vardar-120) connected to the ROG Fan Controller all exhibit a high-pitched whine when powered, especially at low and medium speeds. The same fans connected to the motherboard's PWM ports do not exhibit the same noise. I think the controller has a problem either with power or PWM, hopefully there will be a future firmware update to correct it.
Tags for this Thread
