Results 1 to 10 of 14
Thread: Z690 Extreme OLED issue
02-19-2022 07:54 AM #1
- Join Date
- Sep 2018
- Reputation
- 10
- Posts
- 3
Does anyone else have issues with the OLED screen crashing? If I go back to Armoury Crate and selecting another preset animation it comes back but it's kind of annoying that it randomly stops working for a bit. I'm on the latest BIOS with all updates installed.
02-21-2022 11:02 PM #2
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 35
Happening to me on an Extreme board too. If I have the OLED displaying CPU temp, etc, eventually it will crash, with weird lines appearing in the OLED screen. First time I saw that I thought the screen was broken or something.
Selecting one of the built in animation loops, however, does not crash the screen EVER. I smell a software issue.
02-22-2022 05:07 PM #3
- Join Date
- Sep 2018
- Reputation
- 10
- Posts
- 3
03-29-2022 08:33 PM #4
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 1
OLED display image is off, to the corner and glitchy
Hi there, I've had this issue with my z690 extreme bought on early February this year. I sent it to RMA through the store I bought it from here in Brazil (Pichau) and had a though time getting a replacement since they told me they were out of stock. Ended up having to buy from another store and was completely focused on monitoring the OLED display. Happens it worked fine with the second board however after a few days (don't know which specific event such as validating Windows or such) it started displaying the same issue. Image is off the display, appearing just at the corner and glitchy. I didnt even touch the display and it started out working perfectly, so I'm thinking it's a software issue and hoping it will be solved soon once more people report it and Asus takes action.
03-30-2022 09:49 PM #5
TSportM PC Specs Laptop (Model) ASUS ROG G751JY Motherboard Z690 Maximus extreme Processor 12900ks@5.700mhz Memory (part number) Tforce DDR5 6400@6800 Graphics Card #1 Geforce RTX 3090@2100mhz Sound Card onboard Monitor 32:9 samsung G9 NEO 2X asus 27 / 1X LG34 Storage #1 crucial 1 tb nme 4.0 Storage #2 4xraid0 1tb wd black / 2Xsamsung SSD 850evo 2TB CPU Cooler Custom LOOP Case Corsair 1000D Power Supply Corsair 1500i Keyboard ASUS Claymore II Mouse ASUS ChakramX Headset Steelseries arctic nova pro Wireless Mouse Pad ASUS SHEATH Headset/Speakers Logitech Z5500 digital OS windows 11 pro 64bit Network Router asus GT - AX11000
- Join Date
- Apr 2015
- Reputation
- 23
- Posts
- 224
same problem here Z690 Maximus extreme
Rig1 - 13900K - P115 - E88- Pcore 5.9/6.1/6.2 Asus Z690 Maximus Extreme - Ecores - 43 - TForce 6400@7000ddr5 - MSI Suprim X RTX 4090@3070mhz - 24gb memory speed - Powerby corsair Ax1500i - Corsair1000d@custom Loop Rig2- 10920X@4.9 - Aorus X299 gaming 9 - gskill 3200@3600 - Zotac RTX 2080Ti - Powerby CM1200 - Noctua NHD15 black - Corsair 900D
05-20-2022 05:21 PM #6
- Join Date
- Aug 2014
- Reputation
- 10
- Posts
- 18
Same Problem Z690 Extreme on latest Bios. I will add that i had the same issue on my Rog Maximus Formula z490 when it was new, took about 6 months for Asus to release a bios update that also flashed the Firmware for the LiveDash Oled and it worked perfectly moving fwd.
05-24-2022 03:27 PM #7
- Join Date
- May 2022
- Reputation
- 10
- Posts
- 34
Same problem with my ROG MAXIMUS Z690 EXTREME
06-22-2022 02:03 AM #8
- Join Date
- May 2022
- Reputation
- 10
- Posts
- 34
22.06.2022 problem still not solved: https://drive.google.com/file/d/1_IE...ew?usp=sharing
11-12-2022 01:53 AM #9
- Join Date
- Nov 2022
- Reputation
- 10
- Posts
- 4
No solution for this yet ? I am also having this problem... and as far as I can see more or less all users are having this problem.... I am pretty sure that this could be fixed with a SW / Firmware update.... so ASUS what are you waiting to fix this or at least to give us info about this problem ?
Thanks !
11-12-2022 05:27 PM #10
- Join Date
- Aug 2022
- Reputation
- 10
- Posts
- 17
