AXE-11000 and WiFi 6 issues
transdogmifier
I'm running an Asus Dark Hero....Supposedly the WiFi card supports WiFi6, and so does the router...
Why can't I see the SSID or connect?
I'm sure it's something I'm doing incorrectly.,...
Windows 11, all drivers updated
Saltgrass
It appears to have an AX200 card which does not support Wi-Fi 6e but does support W-Fi 6 or ax. So you should be seeing the SSID on the 5 GHz radio but not the 6 GHz radio.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
transdogmifier
well then it doesn't truly support WiFi 6, then does it?
typical.
Saltgrass
I need to know what you are referring to by "it" not supporting.
The system does support Wi-Fi 6, just not Wi-Fi 6e. It can get confusing because the "e" designates the 6 GHz band and without the "e", only the 2.4 and 5.0 GHz bands are supported. You would need an AX210 Wi-Fi card in order to see the higher frequency. Make sure and verify in the Device Manager you do actually have the AX200.
I will tell you this, those cards can be changed out but it is not easy and I would not suggest trying.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
