Results 1 to 2 of 2
    ROG Member Array Gamingfail PC Specs
    Gamingfail PC Specs
    MotherboardASUS Maximus VII Formula
    ProcessorIntel® Core™ i7 4790K
    Memory (part number)G.Skill 32GB DDR3 2400MHz
    Graphics Card #1ASUS GeForce GTX 1080Ti ROG Strix Gaming
    MonitorASUS ROG SWIFT PG278Q
    Storage #1Seagate SSHD 2TB
    Storage #2Samsung SSD 850 EVO 250GB
    CPU CoolerASUS ROG STRIX LC 240
    CaseNZXT Phantom 820 White
    Power SupplyCorsair RM1000
    Keyboard Logitech G513 Carbon Romer-G Tactile
    Mouse Logitech G403 HERO
    Headset Logitech G935
    Mouse Pad ASUS ROG Sheath/Logitech G640 Large Cloth
    OS Windows 10 Pro 64-Bit
    Network RouterASUS RT-AC5300
    Gamingfail's Avatar
    Aug 2014
    8
    ASUS Strix 3070Ti red led flashing lights around PCIe power cable
    Hi a week ago I had power failure throughout the city, after that I noticed red led flashing lights around PCIe power cable I found a forum at Nvidia where another have the same problem read a comment one should unplug power cable from power supply and wait a bit and put it back in and it worked but after a few days it started again with it. One can also download ASUS GPU Tweak which is a feature to disable. Is it normal with ASUS Strix graffiti cards or is it a bug on cards? My computer works but it flashes while on and off. I've found out. It is random when I turn on my PC that it does so but I turn off the power supply on the button stops it. Computer works even if it flashes. I built my PC in January
    PC info
    OS: Windows 11 Pro 64-Bit
    Motherboard: ASUS ROG STRIX X570-E GAMING WIFI II
    CPU: AMD Ryzen 9 5900X
    GPU: ASUS GeForce RTX 3070 Ti ROG STRIX OC
    RAM: G.Skill TridentZ RGB DDR4-4000 C18 QC - 32GB
    Power Supply: Corsair RM1000x (2021)
    NVMe SSD: Samsung 980 PRO - 1TB
    NVMe SSD: Samsung 980 PRO - 2TB
    New ROGer Array Ribellu PC Specs
    Ribellu PC Specs
    MotherboardAsus Maximus Z690 HERO
    ProcessorI7 12700KF
    Memory (part number)Corsair Vengeance DDR5 2X16Gb 5200Mhz 38/38/38/74
    Graphics Card #1Asus ROG-STRIX-RTX3080TI-O12G-GAMING
    MonitorAsus VG27AQ
    Storage #1SSD Samsung 970 EVO Plus 1T
    Storage #2SSD Samsung 960 EVO 500gb
    CPU CoolerMSI MAG CoreLiquid C240
    CaseThermaltake Commander C31 TG
    Power SupplyCorsair HX850
    Keyboard Razer Huntsman Tournament Edition
    Mouse Razer Bazilisk V2
    Headset/Speakers Hyper X Cloud Alpha
    OS Windows 10 Pro 21H2
    Dec 2021
    36
    93
    I had this problem only once with my Asus 3080Ti ROG Strix 012G, and as you mention, I simply unplugged the power cable, waited 5 minutes, plugged it back in and the leds had gone out.
    I haven't had this "problem" since.
    Seems to be a bug maybe in the firmware or a component, I don't know, because even with the leds on the GPU works normally.
