Results 1 to 5 of 5
03-29-2022 07:36 PM #1
- Join Date
- Mar 2022
- Reputation
- 10
- Posts
- 3
Crosshair VIII Impact: black screen and fan goes crazy
Hi there
I have a ROG Crosshair VIII Impact motherboard with an AMD Ryzen 9 and often (80% chances) when resuming from suspension I get a black screen and all the fans going to top speed. This also happens if I quickly open Chrome once system boots up from a power-off.
Has anyone ever experienced this? I am completely at a loss here, I suspect it has something to do with the motherboard or the RAM.
The Q-Code displayed is 00...that absolutely doesn't help.
03-30-2022 05:04 PM #2
- Join Date
- Mar 2022
- Reputation
- 10
- Posts
- 3
I have noticed that the on-board DRAM LED (yellow) is ON when this failure happens. Any ideas?
04-30-2022 07:26 AM #3
wrong tread post, try under the motherboard section.
05-03-2022 02:20 AM #4
world PC Specs Motherboard ASUS PRIME X470-PRO Processor Ryzen 3600x Graphics Card #1 ASUS ROG Strix 1080 ti Sound Card Aune T1 DAC CPU Cooler Thermaltake Water 2.0 Case Jonsbo U4 Power Supply Cooler Master V1200 Mouse Asus ROG Chakram X Headset Sennheiser HD598
- Join Date
- Feb 2017
- Reputation
- 47
- Posts
- 75
Hey hus3di,
Do you have anything overclocked or undervolted on your system?
Also, have you changed anything else in the BIOS? If you have, try resetting to defaults and see if you're still getting the same issue.
05-03-2022 03:45 AM #5
- Join Date
- Jan 2011
- Reputation
- 20
- Posts
- 463
Try going down a few bios versions. Good part is you can on your board. On my board you are stuck like Chuck. Hopefully, an earlier bios will sort out your issue on the board.
